new 3d park flyer
new 3d park flyer
due to the demise of my favourite little plane i am making a new, improved 3d parky. power will be the same. himark 28/12/1200kv outrunner on a 9x3.8 prop, ebay 18 amp esc, 3s1p 1050 kokam ( later upgrade to a 2200 ). 2 8.8g park flyer servos and a blue bird 13 gram on the ailerons
RE: new 3d park flyer
it will weigh in at about 390 grams at this point ( still have to mount the wing yet, its just pinned in place ). the span is about 850mm. covering is a mix of clear monocote, blue oracover and pink profilm. 2mm rod carbon spars
well its in ready to fly condition but the cheap ebay esc fried itself ( dont know why i only used it 4 times ). its was cheap and i will buy another one while they are still 1/5 the price of a brand name equivilent
well went for the test flight early this morning and what can i say, i stoked. it can knife edge loop on low rates and can roll about 2 times in a second. high alfa is a little high on the throttle stick hovering at about 3/4 throttle but i assume im only pullin about 8-10 amps with the 8x4e apc on the high mark 1200kv outrunner. grass was too long (thick and about 3 inches high) so i had to hand launch it, to my pleasent suprise it tracked dead straight, to get it out of trees harm i pulled vertical and went straight upfirst thing i wanted to try was knife edge, sadly the roll coupling was very high, so im going to experiment with different rudder set ups starting with one half the size( it knife edged with like 5 clicks of trim ). it slows down and lands better then a trainer untill its 1 1/2 inch wheels hit the long grass, it endo'd into a violent stop. no damage done and now i can't stop grinning
