attempting to cut out a new shocky
IL
well as i happened to destroy my ikarus superstar not too long ago, i decided to cut another one.........but i didnt trace out the parts.....because i found it in the garbage....still in pretty much one piece..........now i just tore it apart pretty much, and im just wondering on glue........should i use CA or hot glue??? and does any1 have pictures of the parts before they were put together, just so i can see what parts are wat.....like which should be with another one, or if all the pieces are seperate........thanks!
IL
RE: attempting to cut out a new shocky
ok because when i built my eflite ultimate (foamy) i used hot glue all the way around, and didnt turn out really heavy, but i want to get this shockflyer as light as i can, i thought i would ask for tips or anythign like that.........thanks!
I always use Odorless CA glue. It's light and it dry's quick with kicker. I only use hot glue to hold the speedcontrol wires and servo wires in place.
Bevo
Bevo
GA
Yeah, if you want it light...use foam safe CA and accelerator
I hotglue the servos, and ESC and reciever in place. Just a drop will do it. Be careful not to melt the foam.
