3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Typhoon Tailwheel Fix.
Old 03-31-2006, 10:16 PM
HitecMan
My Feedback: (43)
Default Typhoon Tailwheel Fix.
I don't know if you typhoon flyers like me were getting ticked off at your tailhweel falling off it's bracket everytime you land but i now have a simple solution. Take a t-pin you use for bulding kits and cut it in half leaving about half an inch of the point left. coat the point in epoxy and stick it on the side of the wire where the opening is. and it wll not slip off again.
Old 04-01-2006, 08:34 AM
jmir
Default RE: Typhoon Tailwheel Fix.
Can you post a photo? I glued a small piece of a toothpick in the opening and wrapped it wth a thin strip of tape. It's been holding on for a while.
ORIGINAL: HitecMan
Old 04-01-2006, 10:12 AM
HitecMan
My Feedback: (43)
Sure. I don't know how well you will be able to see it.
Old 04-01-2006, 11:54 AM
olds455
I havent had any problems with the tail on mine. I dent the main gear up on a bad landing, But ive only flown it about a dozen times.
