3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Katana Mini
Old 04-01-2006, 04:01 PM
cojim14
Default Katana Mini
I've been closely looking at the Katana Mini from Atlanta Hobby and need to know what a good, powerful setup would be for that plane. If you own one, what are the electronics you're using? This is my list so far (everything is from Atlanta Hobby.com):
APC 10x6 E-Prop
Hacker A30-22S brushless motor
Hacker X-30 brushless ESC
Thunder Power 2100mAh 3-cell li-po
Hitec HS-55's all around
Hitec 6in. Y-Harness
(2) Hitec 12in. servo ext.
Castle Creations Berg 4
I may only need 6in. servo ext. but the 12 and 6 are the same price so what the heck. The reciever is really cheap and top quality. Thanks in advance for your ideas!
Cojim14
Old 04-01-2006, 05:17 PM
Ryguy
Default RE: Katana Mini
Get the Torque 2830 motor instead, or at least the A30-28S. The 22S has too high of a KV. I run the Torque 2830/1080 and love it. Get an Electron 6 instead of the Berg, or at least a 6 channel receiver. This plane likes spoilerons for harriers. Also, get a APC 11x4.7 SF instead of the 10 incher, to KE well you need at least an 11 in. prop.
If I could do it again I'd get the Himax 2025 and a Cobri gearbox. Then you can turn a 12x6 prop.
Hope I helped!
Old 04-01-2006, 06:33 PM
novabill
ORIGINAL: Ryguy
Hope I helped!
I'd get this gearbox with a Himax 2025-5300 or Hacker B20-L. It's made for the Katana Mini (by precision Aerobatics) and only weighs 14 grams.
ID:	437199   Click image for larger version
ID:	437200   Click image for larger version
ID:	437201   Click image for larger version
Old 04-01-2006, 06:42 PM
Ryguy
I've heard of several people bending the shaft on that one, and replacements aren't easilly available in the US.
Old 04-01-2006, 07:08 PM
novabill
ORIGINAL: Ryguy
We'll have all the shafts you need.....
Old 04-01-2006, 07:35 PM
Ryguy
Cojim14, you PMed me about my setup.
Torque 2830-1080
APC 11x4.7 SF
Integy 3S 2100
4 HS-55
Hitec Electron 6
Phoenix 35
Enlarged rudder (not tested yet...)
My KM is currently needing repairs. That's what happens when the sun gets in your eyes while doing a rolling harrier only 20 feet up....
Old 04-01-2006, 07:41 PM
novabill
ORIGINAL: Ryguy
Torque 2830-1080
APC 11x4.7 SF
Integy 3S 2100
4 HS-55
Hitec Electron 6
Phoenix 35
That's a good setup
Old 04-01-2006, 07:46 PM
cojim14
Atlanta Hobby suggests the 2830/1095 instead of the 2830/1080. Is there much of a difference performance-wise?
