Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
Question? Great Planes Lipos with 20c and load balancing
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 04-03-2006, 10:33 AM
flight_22
My Feedback: (51)
Default Question? Great Planes Lipos with 20c and load balancing
Will the new great planes 640mah Lipos with the 20C discharge and load balancing give better performance than the current GP 640mah 15C discharge Lipos on their flatouts with the rimfire? I am assuming the runtime will be significantly reduced.
See Tower link below.
http://www2.towerhobbies.com/cgi-bin...?&I=LXMDM5&P=7
SPECS:
Capacity: 640mAh
Number of Cells in Series: 3
Rated Voltage: 11.1V
Max. Charge Voltage: 12.6V
Min. Discharge Voltage: 7.5V
Maximum Recommended Charge Current: 640mA
Continuous Discharge Current: 12.8A (20C)
Discharge Lead: 18AWG 3.1" (80mm) long wire with Deans Micro plug
Charge Lead: 24AWG 1.6" (40mm) long wire with balance connector
Pack Dimensions: 65 x 40 x 16.5mm (2.55 x 1.57 x 0.65")
Weight: 2.01oz (57g)
Old 04-03-2006, 03:22 PM
Ryguy
Default RE: Question? Great Planes Lipos with 20c and load balancing
The flight time will be the same, but you will get a little more power because the voltage won't drop as much.
