Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
E-flite Extra 260 3D Profile
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 12-11-2006, 11:09 PM
mudpuppy
Default RE: E-flite Extra 260 3D Profile
Just to reiterate, Hot melt glue does not hold the servos in well. Use foam safe CA to glue the servos in. I have had to re-glue all 4 servos now due to hot melt glue failures. This little foamy does not handle well when a servo is trying to bail on you.
Old 12-22-2006, 11:41 PM
mudpuppy
Snow, snow, snow. That's all we get any more. Sure puts a damper on outdoor flying. Maybe i'll look into some ski landing gear
Old 12-30-2006, 08:38 PM
green river rc
green river rc's Avatar
I got one for Christmas, it's my first flat foamie/lipo/brushless ever and I have been flying for several years. I fly mine with a Rimfire 1000 and a 640 mha battery and Futaba 3110 servos. I had an old Hitec 555 but it fried on me after the 1st flight, I threw in one of those big ole Futaba 7 ch until my new one comes in.
All I can say is AWSOME! I had no idea they were this easy to hover, and torque roll...Will practacly do it by itself. And if you get in trouble just chop the power and lay it gently on the ground. I'm not near the flyer as Greg in the video but I can usually hang one up and keep it there. I'm still kicking myself for not doing this sooner, it's a freekin' hoot!
Old 12-30-2006, 11:25 PM
lthibault
lthibault's Avatar
Any feedback on the variable pitch setup? I've got one installed with the 370 motor. I use a flap/gear mix on my JR radio so I can reverse the thrust instantly with the gear switch.
I try to avoid overamping with excessive pitch. Since I have no instruments to monitor the amps I increase the pitch gradually and check the battery and motor temperature.
The JR sport receiver is very sensible to cold temperature. Servos won't respond if the receiver is exposed to temperatures below 5 degrees Celcius! So Outside flying is not an option for me.
Old 01-02-2007, 09:04 PM
green river rc
Greg Covey,
That's some fancy flying...are you using a Y- harness on your alierons or are you mixing them with elevator coupling?
David
Old 01-02-2007, 11:43 PM
  #31
Ryan Nau
My Feedback: (54)
Ryan Nau's Avatar
i got one for christmas, nice little foamy kit. it will be interesting to see how this foam is compared to others. Im going to use an Axi 2208/34, 9x3.8, and 3c640
Old 01-03-2007, 10:18 AM
  #32
maineflyer
My Feedback: (44)
maineflyer's Avatar
I got a couple of these for Christmas also and am putting a Eflite 300 on it with a Berg 4L reciever and TP 730 pro lites and S60 s all around. Can't wait to fly it.
Old 01-06-2007, 06:01 PM
  #33
sticks-RCU
My Feedback: (23)
I purchased my 260 about a month ago and have had a total blast with it. Now the big question, I have 4" of snow out side so what are some creative landing techniques, I don't think I want to get things wet by landing in the snow?
Old 01-06-2007, 06:17 PM
  #34
green river rc
What kind of speed control is everyone using? I have an Electrifly SS-12 and it keeps cutting off on me. I wonder if the one that E-flight reccamends is better.
Old 01-07-2007, 09:25 AM
  #35
mudpuppy
green river - What prop are you using? Too much prop or too heavy of a prop will cause the esc to cut off.
I use a CC Phoenix 10 and it too was cutting off on me until I programmed it to soft cutoff and no brake. Now no more cutting off [8D]
Old 01-07-2007, 10:57 AM
  #36
rc-sport
My Feedback: (12)
rc-sport's Avatar
ORIGINAL: sticks-RCU
sticks, do like I did with my Mini Funtana....build little skis
Old 01-07-2007, 05:45 PM
  #37
rc-sport
My Feedback: (12)
rc-sport's Avatar
I maidened mine today indoors, it flies real heavy. Hope it flies better outdoors.
Old 01-07-2007, 08:59 PM
  #38
green river rc
mudpuppy
I'm using an APC slowflyer 9x3.8
Old 01-07-2007, 09:17 PM
  #39
mudpuppy
9" prop is too big. I'm using an APC 8x3.8 (recomended in then manual). The GWS props are a hair lighter and can help also.
Old 01-07-2007, 09:22 PM
  #40
green river rc
I'll give it a try tomorrow.
Old 01-07-2007, 09:30 PM
  #41
mudpuppy
lmk how it goes.
Old 01-07-2007, 10:55 PM
  #42
sticks-RCU
My Feedback: (23)
RC-Sport I like your idea, do you have a picture of your little skis?
Old 01-18-2007, 06:22 PM
  #43
hobbydude214
My Feedback: (13)
I love my extra. All the carbon fiber is off it except for the tail struts and the wing. pull-pull rudder, single aileron servo, very light!
ID:	601031   Click image for larger version
ID:	601032   Click image for larger version
ID:	601033   Click image for larger version
Old 01-18-2007, 10:05 PM
  #44
VictoryRoll-91
VictoryRoll-91's Avatar
It looks very...stringy. But good!
Old 01-19-2007, 12:37 AM
  #45
hobbydude214
My Feedback: (13)
My specs are: micro cyclon, multiplex speed controller i think 10 or 12, hs-55 aileron, pico elevator, and blueberg306 rudder, blueberg rx, 10x3.8 apc, engineering.
Old 01-31-2007, 10:20 PM
  #46
mudpuppy
After a month or so of not flying this little bird due to snow, I decided to install the landing gear and start flying it again. Still only about 8.3 ounces and now I can land in parking lots and on the runway at the field. Great to be flying the 260 profile again!
Old 02-01-2007, 05:07 AM
  #47
maineflyer
My Feedback: (44)
maineflyer's Avatar
I am still waiting for a receiver so I can fly mine. I have an AR 6100 on order but its backordered. I can't wait to get it into the air!!
Jeff
Old 02-01-2007, 08:14 AM
  #48
mudpuppy
I hear ya Jeff, I'm waiting for one as well. Sure would be nice if new products were readily available.
Old 02-20-2007, 10:59 PM
  #49
mudpuppy
Finally... my AR6100 has arrived. I sure wish that I had ordered 3 instead of just 1.
Is it spring yet?
Old 02-21-2007, 05:03 AM
  #50
maineflyer
My Feedback: (44)
maineflyer's Avatar
I just got mine also. Finished the plane last night with a Eflite 300, TP 730 Prolite and S-60s around and it came out at 8.1 oz w/o gear. I can't wait to fly it but it is very cold and snowy. I would love to try it indoors if there was a spot here. Oh well, got 2 glow projects to get to now, before spring.
Jeff
