Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
Precision Aerobatics Katana MD Build and Fly
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 05-01-2007, 03:20 PM
itai
itai's Avatar
Default Precision Aerobatics Katana MD Build and Fly
Hi guys
this is my new katana MD from Precision Aerobatics
it arrived today all the way from Australia.you cant get them here.so what can i say
thanks Adad for the excellent customer service
i will try to keep you posted and I welcome ALL KMD owners to join in and share pics, setup and tips
Old 05-01-2007, 03:23 PM
itai
itai's Avatar
Default RE: Precision Aerobatics Katana MD Build and Fly
here some pics
ID:	676049   Click image for larger version
ID:	676050   Click image for larger version
Old 05-01-2007, 05:05 PM
clovus
clovus's Avatar
Cool!
Looks nice, expensive tho' Hurry up and build fly it will you!!
Old 05-02-2007, 02:04 PM
VictoryRoll-91
VictoryRoll-91's Avatar
I love "do not crash" warning on he box.
Old 05-02-2007, 02:24 PM
itai
itai's Avatar
it's a good one
ORIGINAL: VictoryRoll-91
Old 05-02-2007, 02:41 PM
itai
itai's Avatar
out of the box all the parts
Old 05-02-2007, 10:12 PM
cliorc
Itai,You'll love this plane,I got mine in Toledo at the WEAK show and been flying the heck out of it,tracks very nice and just floats.Olin
Old 05-03-2007, 04:06 AM
itai
itai's Avatar
what prop are you using
Old 05-03-2007, 01:03 PM
cliorc
I'm running a APC 12x6E,Torque 2818-900,Air Boss 35amp ESC,T.P. 2070 3s,AR7000,HS-65HB's.Olin
Old 05-04-2007, 03:31 PM
itai
itai's Avatar
i will try the thrust 30
Old 05-04-2007, 04:31 PM
itai
itai's Avatar
look at the wing
Old 05-04-2007, 04:43 PM
itai
itai's Avatar
look at this wing hinges just like composite!
Old 05-05-2007, 03:03 PM
itai
itai's Avatar
estimat weight of the airplane only is 582 gr 20.5 oz
and these parts:
motor thrust 30 110 gr
servo futaba s3110 8 gr
lipo evo 2170 170 gr
servo extensions 6 gr
esc 28 gr
spinner 6 gr
prop adapter 8 gr
prop 15 gr
367 gr 12.9 oz
estimate 949 gr 33.5 oz
Old 05-05-2007, 03:22 PM
itai
itai's Avatar
sorry i forgot the reciver
gws 6ch naro type 8 gr
so estimat weight 957 gr 33.8 oz
Old 05-06-2007, 05:08 PM
itai
itai's Avatar
Got some work done yesterday
I removed the covering film from the elevator servo, wing bolts, horizontal stabilizer, wing tube, anti rotation pin, pull pull servo cables, and landing gear.
On the wing tube I used a heated safety pin, came out perfect .
I finished the landing gear and the wheel pants.
ID:	678975   Click image for larger version
ID:	678976   Click image for larger version
ID:	678977   Click image for larger version
ID:	678978   Click image for larger version
Old 05-06-2007, 09:31 PM
aerofundan
nice!, you will love it!, i made a video of mine here:
http://aerofun3d.com/videos/KatanaMDV3M.wmv
Old 05-07-2007, 08:10 AM
itai
itai's Avatar
cool !
daniel i saw this video before, very nice flying
what is your setup
motor ?
batt?
esc?
prop ?
Old 05-07-2007, 09:35 AM
aerofundan
ORIGINAL: itai
cool !
what is your setup
motor ?
batt?
esc?
prop ?
Thanks!, setup is PA Thrust 30 motor, battery is PA 2200 12-15c 11.1V, prop APC 12x6E
Daniel
Old 05-07-2007, 03:22 PM
itai
itai's Avatar
did the elevator today
ID:	679654   Click image for larger version
ID:	679655   Click image for larger version
ID:	679656   Click image for larger version
ID:	679657   Click image for larger version
Old 05-07-2007, 06:30 PM
Snootch
My Feedback: (14)
ORIGINAL: itai
Looks good itai. I’m almost done building mine (red one)
But I noticed that you missed the 2 washers that supposed to be installed under the 10mm M3 bolts keeping the landing gear legs attached to the fuselage.
I’m still waiting for the Thrust 30 out-Runner motor and replacement double pull-pull servo arm. ( I hate that easy connector for pull-pull rudder design )
Ralph P.
Old 05-07-2007, 06:45 PM
aerofundan
thats right, its a good idea to put the washers on the LG, and also remember to put them on the motor mount, it will help spread the load over all the area.
Old 05-08-2007, 08:46 AM
itai
itai's Avatar
thanks Snootch
i did not forget the washers it is not finishd yet . as you can see two other bolts are not there even i have to enlarge the hole a little for the self-tapping screw
but you got good eyes.........
what problem do you have with connector for pull-pull rudder
itai
Old 05-11-2007, 05:55 PM
itai
itai's Avatar
i got the rudder done
ID:	682423   Click image for larger version
Old 05-16-2007, 04:09 PM
itai
itai's Avatar
I did not want to mount the tail wheel on the rudder. I wanted to prevent shocks and vibration during landings and transport to the rudder So I Modified the tail wheel.
I used the original tail wheel that was supplied by precision aerobatics and I added a strip of aluminum that i fitted with two screws that hold it in place at the end of the fuselage. Then I fitted a small tube on the wire, glued with epoxy and I drilled a hole and penetrated into the fuselage. using the same method of the z bend bind the spring to the wheel using a piece of string soak it with thin CA and allow it to dry.
I glued a short peace of plastic tube to the rudder and inserted the end of the spring to it. Works great' weight is 2 gr.
ID:	685727   Click image for larger version
ID:	685728   Click image for larger version
Old 05-16-2007, 09:10 PM
3D-Flyer Kevin
Cool looking great!!!
Kevin
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
