Yak 54F
Yak 54F
would you think this setup would work on a E-Flite Yak 54F?
3x Tower Pro 9g servos .... http://www.servoshop.co.uk/index.php...90G&area=Servo
RichModel 25 amp ESC.
A 3s 800mah lipo battery.
I also have a CENTURY 6 CHANNEL MICRO RECIEVER ... http://www.centuryuk.com/Products/Radio+Equipment?pos=3 ... That should work, Hopefully.
I need a brushless motor .... Which one of these Dualsky motors would work on the E-flite yak? .... http://alshobbies.com/shop/cat.php?id=358&Desc= (does anyone have any experience with these? do they have Tapped holes in the front of the motor ( the side that the shaft comes out from ) so i could mount them the way the manual says?
What else would i need?
Jonathan
Jonathan
RE: Yak 54F
A 9 gram servo is going to be a little heavy in my opinion for this plane. I have 6 gram servos in mine, and it seems just about right.
I think you are going to want a little bigger battery. The specs. call for a 1300mah, or there about. I am running the 1320 3 cell Thunder Power in mine. Your flight times will be pretty low with a 800mah. I am getting 10 minutes with the 1320mah.
This motor would work:
http://www.jperkinsdistribution.co.u...rs%20-%20E-Pro
This one would be border lien, not quite enough power in my opinion
http://alshobbies.com/shop/lookupsto...?pc=5434&Desc=
This would work too
http://www.jperkinsdistribution.co.u...tors%20-%20GWS
Run a 11x4.7 SlowFly. The performance will be excellent. I am hovering around half throttle.
This would work too
RE: Yak 54F
i've got a 1500mah 3s lipo, would that work?
Anyone have any experience with the Aipower Brushless motors?
And also, which one will give me more power the GWS one or the E-pro?
RE: Yak 54F
The 1500mah would be close to being too heavy. You could try it.
Look at which motor has a higher watt rating, that one will give you more overall power.
