Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
Best Foamie for AXI 2208/34?
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 07-27-2007, 05:19 PM
RC-3D
Default Best Foamie for AXI 2208/34?
I'm looking for best 3D foamie airframe for my AXI 2208/34 and jeti 8 amp ESC, Any idea anyone?
Tom
Old 07-27-2007, 08:00 PM
rmenke
My Feedback: (13)
Default RE: Best Foamie for AXI 2208/34?
RC-3D I love the yak 54 of www.rcxplanes.com. Motor is a tad light according to the specs of the plane manufacturer, but had one with this setup, and flew very well, about 14-16 minutes of full 3d. No hover/blast out problem. TP 1320.
Old 07-27-2007, 10:56 PM
altavillan
Or here ---------->http://chargerrc.com/osCommerce1/catalog/
Old 07-27-2007, 11:34 PM
RC-3D
Altavillan, Which one? CR-1?
Tom
Old 07-28-2007, 08:31 AM
altavillan
I have tried them all except the cr1. The CR2 is my favorite but the shifty comes close. The extra comes in last in my opinion, you cannot relax when it is close to the ground. If you get one build it with white glue or carpenters glue and it will be stronger. Use the Foam Ca for repairs and control horns. And call Tim and ask if the stock motor mount will bolt to the Axi. To mount the servos hot glue them in then masking tape over them. Use masking tape to install the CF spar and save the hinge tape. Double bevel the hinge lines to 45*. I tape the surface to be beveled to a piece of glass and hold a straight edge on top to get a perfect cut. The plane comes with complete hardware. You will want to balance it a bit behind recomended for easy hovering and to not have nose dives when the BEC shuts off the motor. About 1/4 to 3/8"
Old 07-29-2007, 08:51 AM
COOLAIR
I have that motor and speed control in a 3Dfoamy Mini Su26 Pro. I get 7-8 min. flights with a 640 pack maybe longer with throttle management. The plane flys great and construction is very durable.
Good luck!
