3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Extreme Flight 300s
Old 11-20-2007, 04:04 PM
td300509
Default Extreme Flight 300s
Hi,
Can someone recommend what servo's to use and do you have any build tips for when I put this baby together, It's the 45 inch one
Cheers
Kev
Old 11-20-2007, 04:35 PM
rmenke
My Feedback: (13)
Default RE: Extreme Flight 300s
TD:
Standard servos should be ok on this. I would be inclined to use JR sport MN 48. Small, light, quick, 48 oz torque and reasonable cost, very good centering. They work very good with my AJ Extra 50" 330L. ENJOY
Old 11-20-2007, 05:44 PM
jmohn
I am using HS85s on mine. No problems ...flys great!
Old 11-20-2007, 05:54 PM
henson
My Feedback: (64)
I used the hs-56s on mine no problems at all.
Old 11-21-2007, 01:26 AM
nitro wing
HS 65 should be ideal too
Old 11-21-2007, 01:56 AM
td300509
thanks for the relies, I have some hs-55 servo's will it be ok to use those ?
Old 11-21-2007, 02:14 AM
tIANci
tIANci's Avatar
I tested the first plane on the GWS Naro servos, it was ok but I never did dare to try any hard stuff, just flying about. I am running on HS65s and its great. I think the HS55s are ok but you will run the risk of stripping servo gears and you cannot push the servo too hard. Mild aerobatics should be ok.
Old 11-21-2007, 02:55 AM
td300509
cheers, I thought they might be not up to the job,
Old 11-21-2007, 10:10 AM
tqcookie
Definately go with the hs 65's. Thay are the perfect match for this plane. Also I think if you buy them with the the plane you get a pretty good break on them. I have probably 200 flight on my 4" with these servos and no problems what so ever.
Old 11-21-2007, 11:41 AM
Witterings
I've just bought one but won't be allowed to get my hands on it until Xmas day [&o] and have bought the HS 65's mainly becasue I've stripped servo gears on other highly aerobatic planes using inadequate servo's before and twice - heavens know's how - have managed to land without too much damage.
Just seems a false economy to save a few quid on some servo's and risk the whole plane along with the time / effort of putting it together when buying one replacement will be more expensive than the extra cost for all 4 in the 1st place.
Hope that helps, can't wait to fly mine but if you get yours out soon let us know what you think !!!!!!
Old 11-21-2007, 10:15 PM
tIANci
tIANci's Avatar
Best to just invest in 4 pieces of the HS65s, keep the 55s for another plane, now you have reason to get another plane!!!
