Airfoilz RCU Extra 260
#76
NJ
Can anyone tell me if these e-flite servos will work ok in the full fuse extra?
9 Gram Sub-Micro Servo Product Specifications
Size Category: Minis and Micros
Type: Analog
Torque: 20oz/in @ 4.8V, 22oz/in @ 6.0V
Speed: .24 sec/60° @ 4.8V, .20 sec/60°
Bushing Or Bearing: Bushing
Gear Type: Nylon
Type: Analog
Gear Type: Nylon
#78
NJ
Thanks for your answer.
I know its not much but will the speed make a difference in flight?
e-flite Speed: .24 sec/60° @ 4.8V
HS-65 Speed: 0.14/60 degrees @ 4.8V
#79
CA
I think you will be good...I have flown the Extra 260 with some off name cheapies servos and worked fine...not as fast as something like the HS-65 or Waypoints servos.
#81
NJ
Thanks for your input guys.Looks like i will use these servos.I dont have the extra cash for 4 new hs-65's right now.You saved me a
few dollars.I ordered the plane and a Scorpion motor yesterday.
#82
CA
ORIGINAL: tj0715
#83
NJ
Im not quite finished with it yet.I got side tracked on a few house projects.Was hoping to maiden it this weekend, but forecast is for rain and high wind.I also did not want to rush building it.When i got my Yak profile, i rushed and made a few mistakes.Worst mistake of all i did not glue the hinges in good enough.The right aileron pulled out in flight,i was able to land with only a small amount of damage.Paul recomended the Turnigy 2217 16 motor instead of the Scorpion 2215 18.Great motor for the price,lots of power,i put it on my Yak just to try it.Hopefully the weather will be better next week.Im sure i will love it, i let you know after i get it in the air.
#84
CA
ORIGINAL: tj0715
#85
NJ
Had some good weather the other day.Got the 260 in the air.WOW!!!!!!This is my new favorite plane.
Some small trim adjustments,then she flew beautifully.Best flying plane i have,im going to neeed more batteries!!!!
#86
CA
ORIGINAL: tj0715
Great to hear...although I knew you'd love it
#88
CA
ORIGINAL: tj0715
Im using Zippy lipos,i have an 1800 and a 2200.Great lipos for the price,lots of power,good flight times (10-14 minutes)with 11x4.7 prop.
#90
CA
ORIGINAL: tj0715
Damm, i love this plane!!!!!!!!!!
[link]http://www.rcuvideos.com/video/airfoilz-extra-260[/link]
