need 3D airframe for hackerB50-15L
My Feedback: (7)
AZ
i n Date: Oct 200
Post what 3d airframe can I use a hacker B50-15L
What 3D airframe can I use this hacker inrunner:
B50-15L
here are the specs from hacker website
Designed for Larger 6-8 Lb. Models, that require very high thrust on 14-20 cells. Planetary Gearbox incorporates "Needle Bearings" for super reliability. The B50 "L" series are used in 3D Funflyers, Competition Gliders, Aerobatic Pattern, Ducted Fan and .40 to .60 Size Sport ARF models.
Idle Current: n/a
Operating Current: 35
Peak Current: 50
Peak Watts: 1200
Resistance: 0.0231
RPM / V: 1610
Battery: 3-6 LiPo
Shaft Diameter: 5.00mm
Shaft Diameter w/GB 6.0mm
Weight 255g (8.95oz)
Weight w/GB 315g (11.05oz
I have an opportunity to get this from the local hobby shop for $75 (brand new in the box..someone ordered a year ago and they want to get rid of it). I could not pass up a motor that costs over $130
I would like an airframe that can handle A123 cells ,that will fly 3D and unlimited verical
this needs a gearbox(never had this typeof setu so any sugestion would be welcom
