Motor for 3DHS 47" SHP?
Any thoughts on this Scorpion motor for the SHP? Looks to have more power than the Torque 2818-900, but also weighs about 2 oz more. http://www.rcdude.com/servlet/the-12...ushless/Detail
TX
RE: Motor for 3DHS 47" SHP?
Randy, at RCDude is very friendly, helpful, and knowledgeable. Drop him an email with you question. Bet he will have some good input. I have Scorpions of two of my acft. They perform WELL.
You will LIKE the SHP. No, mine does not have a Scorpion on it.
I too have a Scorpion in an EF Extra, it's been a great motor. Randy's actually the one who recommended the setup I inquired about in the 3DHS SHP. My only concern with the extra 2 oz would be balancing it for 3d. Looks like the battery bay is large enough to allow the battery to slide back quite a bit in order to help out.
My Feedback: (48)
CA
That motor will work, but for the SHP to really shine for 3D, you want to keep it as light as possible. The extra 2 oz. will be noticable compared to a lighter motor.
If you want to spend a bit less, the Turnigy SK 35-36 1000kv, or the bigger 35-42 will give you more than enough power. I've been running my Acro Master with the 35-42 and it has nearly unlimited vertical on 3s and a 12x6. You can easily prop bigger as long as the ESC is strong enough. I'm running about 50-55A static with that setup.
ORIGINAL: medcinmn
If I were you I'd try and stick with a motor around the 104 gms level like the Torque, I use the Hacker A30-16m which is around the same weight and it still needs a small amount of tail weight to get the plane absolutely balanced and hands off for inverted flight.
