Xoar props
Using a 15x10 regular gas beech prop,anybody know if there,s a benefit to using the thin electric xoar,they are not as wide but I imagine lighter,this is on 6,S power 60 setup,any info great,thanks
RE: Xoar props
I've had good luck with there props
not sure the difference maybe the hub and weight they are not expensive I'd buy one and try it out in the air and the wattmeter I think they have a new prop coming out with carbon Tips and beech wood ! |
RE: Xoar props
Their E props have a thinner hub and are significantly lighter. It's the spool up in RPM's where you'll see and feel the difference. There is a reason they make 'em! :D
