RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   Hovering Problems (https://www.rcuniverse.com/forum/3d-electric-flying-237/2000369-hovering-problems.html)
zagibond 07-17-2004 10:59 PM
Hovering Problems
I am teaching myself to hover with a foam factory Edge 300 powered by an Axi 2212/34.
Problem is that when vertical, the left wing alwys seems to want to drop or a lot of right rudeder is required to keep it straight. In other words that plane wants to turn anticlockwise on the vertical plain. One more clue is that underpower it flies straight and true with quite a bit of right aeleron trim. When it speeds up in a dive it tends to want to lift the nose and arc upwards.
My thoughts are that my thrust angles on my motor are not quite right, perhaps I should give it a bit of right and up thrust? Also, with the battery in place, on the left side of the fuselage it seems a bit heavier on that side, so maybe a bit of weight on the right wing tip?
Chris-B-chips 07-18-2004 12:28 AM
RE: Hovering Problems
it sounds like tourqe n the hover. all planes need a lttle imput to hover. i wouldn't worry about it. as for the nose climbing it sounds like a rearward c of g. how much down elevator does it need inverted?
3dandpatternflyer 07-18-2004 11:12 AM
hey chris,
i like your signature! :):D:):D
Taildragger726 07-18-2004 03:32 PM
Edge 300?
zagibond 07-18-2004 10:34 PM
Extra300 36" sorry.
Will check the cg by flying inverted.
When I do a loop it always seems to roll out of the loop the same way. To stay in the loop I need to use a lot of right aeleron. Is that normal?
What is coupling?
Lots of questions but how else does one learn?
Chris-B-chips 07-19-2004 01:10 AM
the rolling out sounds like a heavy wing. hope ytou get it fixed
3dandpatternflyer i like your signature as well.!!!LOL:D
AMA 74894 07-19-2004 03:44 PM
I agree with Chris B....
Check the LATERAL balance... I'd wager the Left wing is heavier...
and that will cause all kinds of headaches...
another real killer is having the control surface gaps uneven. if the airplane does not track well through loops,
balance laterally, and seal the hinge gaps (if not already sealed.)
Hope that helps!
(BTW, the term "Coupling" is when you command one flight control, and the result includes a second <uncommanded> control input)
when in knife edge flight, (with lots of rudder) it's common for the airplane to need elevator input to keep it flying straight....
the cause of that elevator input requirement is Rudder\Elevator coupling.
zagibond 07-19-2004 06:43 PM
Thanks guys. I might have bigger issues.
My crystal fell out of my RX this weekend. The subsequent contact with the ground was not pretty.
Who knows, the extra epoxy might balance the plane. I will let you know when all is better.
3dandpatternflyer 07-19-2004 06:48 PM
Did u get yur kits yet?? Mine is taking forever! Which one did u get? I'm getting the Sukhoi and Cap232.
TTyl,
Andrew T.
Chris-B-chips 07-20-2004 03:45 AM
nope. my kit has not arrived yet. i orded the cap 232 and the accessories kit. i wish i had waited though. apparently 3dfoamy is getting these plans for a biplane that flies alot like the tensor 4D.
i can't wait to get the cap! should be a killer plane!!!!!!!!!!!!!!!!!!!
3dandpatternflyer 07-20-2004 11:29 AM
We must have the same taste. First the Katana, now the Cap. LoL.:D
The Biplane that they're coming out with should be kewl.;)
TTYl,
Andrew T.
ZimboRaider 07-20-2004 02:43 PM
Andrew and Chris,
I ordered the Extra 300 LX but havent got it either. Maybe we overloaded Levi with our orders?
Anyway, I cant wait for mine!!:D
Zimbo
zagibond 07-20-2004 06:13 PM
Thanks for hijacking my thread.
3dandpatternflyer 07-20-2004 07:10 PM
that new Tiburon Bipe looks awesome.
No Problem ;) Ill start a new one guys.. Young Guns Program, We can all talk there
TTYl,
Andrew T.
Chris-B-chips 07-21-2004 03:00 AM
1 Attachment(s)
sorry zagibond. have ypou managed to fix the problems yet. i am pretty sure its a heavy wing. you could either add weight to the wing thats lighter or preferably move the battry so that its in the center of the fuse. here is a pic showing what i mean:
