RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   Berg 5 on Tensor Question (https://www.rcuniverse.com/forum/3d-electric-flying-237/2529317-berg-5-tensor-question.html)
Dennis Tampa FL 01-11-2005 08:30 PM
I just picked up a Berg 5 Reciever and now realize that I have the one with Pins Up VS Pins Out, IE the one I have has the pins stick up from the case vs sticking out from the side. It will be used on the Tensor 4D and Shockflyer/Chuckflyer's
By looking at it, would it be better to have Pins Out the side to have a smaller profile with the servo connecters parrellel to the fusealoge?
1, Will it be OK to use the Pins up or will it be too high a profile with the servo leads sticking out?
My LHS only had the one:'(
Another Question the LHS also put a JR Crystal in it and at home I check the RC-Direct website and it says to only use Berg Crystals.
2, Will the JR crystal be OK to use?
Thanks in Advance, Dennis
qweedqwag 01-11-2005 08:37 PM
RE: Berg 5 on Tensor Question
Use what you have I say, or at least test it and see if it works for you.
Mike.
cleyland 01-11-2005 08:41 PM
Your reciever will be fine. Not sure about the crystals though.
bdavison 01-11-2005 10:11 PM
I have a GWS reciever in my Tensor that is Pins Up. Dont worry about the plugs and wires sticking out. It wont affect how the plane flys. Works fine.
I dont know about your crystal thing though.
