Himaxx 2812-0650 will it pull U-Can-Do Flight Flex??
Will this size motor 2812-0650 pull a u-can-do-flight flex 3d airplane?? Im looking for a cheap motor, price range around 50 - 70. Whats the best i can get?
http://www2.towerhobbies.com/cgi-bin...?&I=LXJPU8&P=7 Thats the airplane. Please help. - Jeff |
RE: Himaxx 2812-0650 will it pull U-Can-Do Flight Flex??
Actually the stock motor provides plenty of power for hovers vertical pullouts and just good old 3d. Just do everything they tell you too do including battery size and you will be quite happy.
I have the 650 and am quite dissappointed..... I bought it to use in 15oz or so foamies and it barely holds them in the air...
it may work for a much lighter plane, like a shocky, but for my 15 -16oz planes I now use a Hacker A20 |
1 Attachment(s)
ORIGINAL: SexyPizzaMan Will this size motor 2812-0650 pull a u-can-do-flight flex 3d airplane?? - Jeff |
I went with you set up/ I just wanted to know about the mounting stick. Do i need to add one as well if i want to use the motor??
If you want to use the cowl you will find that it is too high when mounted to the stock mount stick. My concern was that it raised the thrust line higher than the geared motor setup. Don't know if that makes a difference. I figured that was where they had it so thats what I would do. Joe
| All times are GMT -8. The time now is 04:31 PM. |
