3dfoamy Advantage and 4d prop?
Just curious if the 3dFoamy Advantage bipe is too heavy for a VPP system?
Finished weight will be about 16oz... I was going to use my Hacker A20, but I wrecked it trying to get the shaft out... darn thing just wouldn't come out[:@] May switch to the Axi 2212 with the hollow shaft already installed........ Think it will work, or should the VPP/4D world stay for ultra-light shock flyers?? Thanks Exeter |
RE: 3dfoamy Advantage and 4d prop?
i dunno.... they say VPP only for >10oz. i guess if you use a really hardcore servo.......
Exeter, show us some pictures of it! Im setting up a VPP on a mini sukhoi this week. Be my first variable setup.
Well...I have the airframe finished, but I haven't installed the motor..
I bent the case of my HAcker A20[:@] trying to get the shaft out to install a hollow shaft, so I need a new motor.... Hopefully I can find a Hacker with the hollow shaft installed, or I may get one of the Axi's from Hobby Lobby that already have the shaft... I tried everything to get the shaft out of my A20 and in turn squished it a bit[:o] |
yea, those hacker shafts are in there so good i doubt they need the set screw... I had to use a vice and a heatgun and it was still a pain in the ass...
| All times are GMT -8. The time now is 03:52 PM. |
