RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   flatana problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (https://www.rcuniverse.com/forum/3d-electric-flying-237/3584072-flatana-problem.html)
nitro125 11-24-2005 01:22 PM
i have a gp flatana and when i turn it on the esc beeps like it should then full throttle it beeps five times like it should then idle throtle stick it beeps 3 times like it should also.But when i give it full throttle it goes to full but then it slowly begins to throttle down until it get to about half thottle down then it just shuts off ive had 3 good flights on it and it worked fine exept it was really windyt and didnt go very fast into the wind and i dont want to fly it until i get this fixed because obiously it will crash if the motor cuts out and doesnt turn bcack on i have the electrifly c-12 esc and the stock motor and a 640mah 3 cell electricly li-poly battery and once the throttle cuts down completley it doesnt go back on even if i re connect the battery also the battery was fully charged right befor i tryed it so please help me!!!!!!
nitro125 11-24-2005 02:18 PM
RE: flatana problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the only thing that doesnt turn on is my motor .....the servos all work and they seem to work fine but the throttle does nothing when i move the stick and the battery pack is full however the esc gets kinda hot when i move the servos around for like 15 seconds or so is this normal ???????????? help please!!111!!!!! i wann try to fly today if the wind dies down
Bax 11-25-2005 12:03 PM
If the motor will go to full, but then slows down to 1/2 or so without you moving the stick, it sounds like your speed control may be bad.
As far as startup is concerned when you've just turned on the system, you have to move the stick to full, hold it there a few seconds, then retard the throttle to idle. The speed control will be armed.
If your speed control's bad, it needs to be sent in to the service center.
nitro125 11-25-2005 12:07 PM
i figured out what was rong . it was a fried motor . i think thta the stock 370 motor doesnt like li-poly baatterys so would i be able to send in the motor and possibly get it fixed under warranty????????????if not i think ill just go with the rimfire and bl-8
