Typhoon 3d
Hiya, just thought I add this little nugget to some of the typhoon articles i've seen so far-just picked up one at my LHS so I can have something to fly in my lunch break!!-anyway,after unpacking everything,I found a little packet tucked under the nimh flight pack-inside was a complete set of spares for all the servos's,and I mean complete!!!. Seems like the manufacturers do listen!!!-Just waiting for the winds to die down the I can maiden her-will keep stock for a while then consider upgrading to EVO 20C 1800 and Axi power(my normal setup)....
wot 4.. |
RE: Typhoon 3d
You'll love the airplane. I own one and I love the way it flies. Everything is stock on mine still and I use the 12 inch propeller that comes with it. Have fun.
Bevo |
RE: Typhoon 3d
Wait, you mean you found extra SERVOS? Not just replacement gears but the WHOLE THING???? Sweet...I need to check inside the boxes at my LHS.:D
RE: Typhoon 3d
I think it my be a local thing as I went back to the model shop and checked ALL the box's-every single box was carrying the extra items-I suspect this may be down to the importer (Helger Racing)-feedback obviously got back to them regarding the poor quality servo's!!!!!!!. Just powered up the typhoon-very noisy g/box and elevator servo is twitchy around centre-goona change that before first flight[X(][X(]
wot 4 |
| All times are GMT -8. The time now is 12:11 AM. |
