RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   Katana prop set-up (https://www.rcuniverse.com/forum/3d-electric-flying-237/4125589-katana-prop-set-up.html)
DHC8GURU 04-04-2006 08:34 PM
Katana prop set-up
I am going to put my e-flight 480 1020kv outrunner in my new Katana. What prop size should I go with?
I was using a 12X6 on my Mini Edge and have a few of those around.
Also I am using a CC PHX-60 ESC with TP prolight 3S1P 2000MAH batteies.
Temporarily going to use an align 25 BL(25 amp constant 35 amp burst) ESC until my Phoenix 60 gets repaired.
Ryguy 04-04-2006 08:37 PM
RE: Katana prop set-up
The 12x6 is the best overall prop for the KM. If you've used it before with success, keep using it.
DHC8GURU 04-04-2006 09:06 PM
Sweeet! I like the APC 12X6 props I have now.
