RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   Stupid Question Regarding a Stick. (https://www.rcuniverse.com/forum/3d-electric-flying-237/4441439-stupid-question-regarding-stick.html)
T. Bob 06-28-2006 02:20 PM
On outrunners that are stick mounted (ie eflight ultimate) what type and size of the wood mounting stick do you use to replace the original one.
123Cat 06-28-2006 04:45 PM
RE: Stupid Question Regarding a Stick.
To save weight I cut them from hardish balsa
If your going to be banging it in a bit use wood it s 10mm by 10mm on my mounts
jdetray 06-28-2006 11:55 PM
If 10mm square stock is not available, you can use 3/8" stock and put a few wraps of tape around it.
- Jeff
T. Bob 06-29-2006 03:07 PM
10mm
I knew it wasnt 3/8s.
Jeff Thanks for the tip.
