EF Yak 55 SP-E outrunner problem???
1 Attachment(s)
I have the Extreme Flight Yak 55 SP-E and am putting an E-flite 450 outrunner on it with an E-flite outrunner stick mount. The problem I have is this mount gets the motor way out front b/c I can only secure the mount to the rear of the motor. Any suggestions?
-Kevin |
RE: EF Yak 55 SP-E outrunner problem???
Do that and your plane will look bad and it will be very nose heavy, what you need is this ...
http://www.jethobby.com.sg/cgi-bin/e...4&cid=25&idx=1 Now this second one is even better! http://www.jethobby.com.sg/cgi-bin/e...6&cid=25&idx=1 I think the outrunner you got is really over powering it, the combo has great power to enjoy good3D. Hope you can find it in the US! |
1 Attachment(s)
Got it. I just cut the mounting stick shorter.
dont see that lasting past the first dorking!
1 Attachment(s)
Yep, It broke.
| All times are GMT -8. The time now is 08:42 AM. |
