Which GP Flat out and recomended set up???
I have 20 years flying glow planes and Heli the only electric experience is whit a Align se T rex, and planing to get a foamy 3d plane and want to know if the recomended set up for a flat out by great planes is OK?? interesed in the maximum battery i can use, incluiding the mini reciver etc..
Thanks for your help I´m 100% beginer in elecric planes |
RE: Which GP Flat out and recomended set up???
Why flatout? I've owned a reflection flatout, it flew pretty good but it was a PAIN to assemble. Anyways, I would consider other foamies also.. If I didnt convince you, I will still give you a good setup.
Rimfire 1000-22m (recommended one) BL-12amp esc Thunder power 910mah 3cell 11.1 lipo, gives you 12 min flight time or a 1320mah which gives you maybe even 20 minutes Any micro receiver, I like 05s from hitec HS-55 servos I think the recommended 640mah pack is too small because it gave me only 5 minutes flights.. Good luck with electrics, they take sometime to understand but they are great once you get used to this stuff :) Paul Teesalu |
also, use a 10 x 4.7SLOFLY prop, this is important if you dont want to fry your electrics.
To elkiwi,
I bought and built the turmoil and cap 580 Paul is right they are a pain to build specially if you have not worked with foam and CA before. I replaced the standard motors with brushless motors as recomended and again as Paul advises used large sloprop 10 x 4 plus. Fun to fly ? sure, in your back yard ? absolutely VERY VERY delicate try to fly off grass. My two bits worth, Good luck. |
I had landing gear problems and I've heard of a couple more people who had problems.. IF you fly off grass, I would simply cut the landing gear off and put foam pads ( on the wings about 1") to protect the bottom servo on the wing. IF you fly off hard surface I would not install the landing gear and buy some stronger CF gear. The stock landing gear is very flexible and it will break off eventually ( or in my case, the 2nd flight :D)
Paul |
| All times are GMT -8. The time now is 06:57 PM. |
