RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   Prop For 3D (https://www.rcuniverse.com/forum/3d-electric-flying-237/5925203-prop-3d.html)
dasintex 05-31-2007 07:57 AM
Prop For 3D
I have a E-Flite Mini Funtana with a HiMaxx Brushless/Gear Box running a 12" dia prop; what Pitch would be best for 3D maneuvers, hovers, torque rolls, etc; Thanks.
Pacific Planes 05-31-2007 11:47 PM
RE: Prop For 3D
Low pitch. 4.7 to nothing over 6. Any where in there should be good. Just remember the lower the slower.
3DSAVAGE 06-02-2007 12:10 PM
RE: Prop For 3D
i use a 10x4.7 on my planes. mine's about the size of a mini funtana, so this setup would probably work...
lwatson 06-03-2007 07:31 AM
RE: Prop For 3D
Let me kick in my 2 cents.
1) use the SF not the E series props
2) use a 12 inch or cut down a 12 inch to 11 1/2
3) use a low pitch 3.8 to 4.5
4) watch the amps
The essense of the problem is to get good airflow across the tail of the airplane. All of the above helps that.
