Problem on assembly of eflight cap 232bp
Got fuse put together on the plane and when i go to put in sevo's they dont fit,the cut out is too small.I am using the s75 like they recomend is this normal on these.If anyone has had this problem how did you fix it???Just sand and trim out?
Thanks for all input Dave |
RE: Problem on assembly of eflight cap 232bp
Just sand and trim the opening. I've found that the planes don't match the instructions anymore. It seems the plans are updated to use the newer micro servos!
| All times are GMT -8. The time now is 07:47 AM. |
