2008 ETOC Sequence with video.
Here it is.....Written description and videos of the 2008 ETOC Sequence.
There will be an Aresti drawing coming soon so stay tuned. TNT is still accepting videos so if your thinking about sending one in, please do so ASAP. Final list of invited pilots will be posted around the first of March. ETOC Sequence Left to Right ETOC Sequence Right to Left 1) Take off. 180 degree turn away from flightline. Straight and level pass. 180 degree turn away from flightline. Take off is judged. K1 2) 45 degree up line. 1/4 roll to Knife edge. Knife edge climb on a 45 up line. 3/4 roll on 45 upline. Push to level. Exit upright. K3 3) 1/2 square loop, Knife Edge Exit. Push to vertical down line. Yaw to exit knife edge and crossing the box. (Radius top and bottom corner needs to match. Must show a line between top and bottom corner.) K3 4) 360 degree Rolling circle. First 180 degrees 3 rolls to the inside. Next 90 degree, 3/4 roll to the outside. Last 90 degrees, 4 of 8 point roll to the inside. Finish inverted crossing the box. K7 5) Tail Slide. Wheels up. Exit upright crossing the box. K4 6) Flat rolling S. 4 point roll to the inside first 180 degrees. 8 point roll to the outside second 180 degrees. Finish upright crossing the box. K6 7) 90 degree turn Upright, 90 degree flat turn K2 8) Roll and Snap combination. 1/4 roll to KE 1-1/2 positive snap opposite direction to KE 2 of 8 same direction to inverted 1-1/2 roll opposite direction. Exit upright. K7 9) Stall Turn. 3 of 4 point roll up. ¾ roll down. Exit inverted. K5 10) Rolling loop. 1/2 roll up. 1/2 roll down in opposite direction. Exit inverted. K5 11) 1/2 square loop with torque rolls. Push to vertical. Perform torque roll. 1 turn. 1 turn opposite direction torque roll. Push to complete 1/2 square loop. Exit level and upright. K5 12) 360 spiral turn to landing. 360 degree turn descending to landing. Landing is judged. K3 |
| All times are GMT -8. The time now is 09:56 PM. |
