RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   prop diff (https://www.rcuniverse.com/forum/3d-electric-flying-237/8843440-prop-diff.html)
Switch_639 06-11-2009 07:04 AM
prop diff
will there be a big diff between a 11x5 and 11x5.5? Iactually want the 5.5 just for recommendation purposes... but if no big deal then I dont care...
DMcQuinn 06-14-2009 09:00 PM
RE: prop diff
Not enough difference to matter.
tIANci 06-15-2009 12:33 AM
RE: prop diff
<span style="font-size: larger;"><span style="font-family: Comic Sans MS;">On paper there will be a difference ... the 11x5 will draw less amps than the 11x5.5 ... however:
i. if you are particular so as not to over prop then the former prop will be what you want;
ii. some may want the revs but not the amps so they will settle with the 11x5.5;
iii. some may want a tad more speed so they will go with the 11x5.5;
iv. some motors may handle either prop better than the other so you test and get the feel you want;
If not it will hardly matter as long as your system can handle the amp draw. To each their own I guess.</span></span>
