Reload this Page >
P.Aerobatics Katana MD with OS 30 4 stroke
Old 10-03-2010, 09:30 AM
simonfly
Default P.Aerobatics Katana MD with OS 30 4 stroke
I have built Katana MD by Precision Aerobatics with OS 30 4 stroke. It flies very well for 15 minutes at least. (fuel tank 6 ounces)
Please, could you tell me the best propeller for this engine?
Thanks a lot
Old 10-03-2010, 10:39 AM
Daniel Z
Daniel Z's Avatar
Location: SantiagoReg Metropolitana, Providencia, CHILE
Default RE: P.Aerobatics Katana MD with OS 30 4 stroke
how much does it weight? power is enough?
Prop 10x4 9x6
Old 10-04-2010, 03:32 AM
Ernie Misner
Ernie Misner's Avatar
Do they still make that plane? Kit or ARF? do you have a link?
thanks,
Ernie
Old 10-04-2010, 01:59 PM
simonfly
The model weighs around 1200 grams (42.32 ounces) and the power is very good with 11x4 propeller. But I want to try other propellers.
At this link: http://www.allerc.com/Pictures/SU31-...Label-1200.jpg
you may see electric plane Hyperion Sukhoi. It weighs 1180 grams and is a little smaller than Katana MD.
1200 grams are a good weight in windy days. 117 cm x 114 cm and 1200 grams are a good dimension and a good weight to take advantage of aerodynamic forces.
This micro model (wingspan 40 cm - weight 25 grams) instead can't take advantage of aerodynamic forces.
The requested link is: precisionaerobatics.com
Old 10-05-2010, 02:26 PM
simonfly
After 5 minutes electric planes []
I don't like them. Too short fun.
Without noise they are more dangerous.
Old 10-06-2010, 04:45 AM
simonfly
But I also have a little electric plane: E- FLITE CAP 232 BP ARF
With two Hyperion Batteries 1600 mAh in series you can enjoy for more than ten minutes.
This model is a blast
But then I like electric planes YES
Old 10-21-2010, 01:57 PM
simonfly
Why is nobody interested in my glow conversion?
Are you all electric flyers only?[]
Old 10-21-2010, 04:37 PM
wyo69cowboy
wyo69cowboy's Avatar
I think it sounds pretty neat; post us some pics or a video. Would love to hear it!
Old 10-21-2010, 04:51 PM
WMB
ORIGINAL: simonfly
I'd like to see a picture of the engine mounting on this. Sounds like a good combo!
Old 10-23-2010, 09:33 AM
kerwin50
simonfly we are very interested we'd love to see some pic's.
I've often thought about glow conversion on the PA aircraft they are good looking planes
Old 10-24-2010, 02:09 PM
simonfly
Some pics of my wonderfull plane
1.bp.blogspot.com/_83Xt7V5Ohpk/TMSBafrZlVI/AAAAAAAAABI/5qUgtBm6RKQ/s1600/IMG_0756.jpg
1.bp.blogspot.com/_83Xt7V5Ohpk/TMSCLyLjADI/AAAAAAAAABQ/E85zrRWTgFc/s1600/IMG_0758.jpg
3.bp.blogspot.com/_83Xt7V5Ohpk/TMSCbckHXsI/AAAAAAAAABY/dzdApVbn0JU/s1600/IMG_0759.jpg
4.bp.blogspot.com/_83Xt7V5Ohpk/TMSCnX1MDDI/AAAAAAAAABg/U3iOo0Jjeu4/s1600/IMG_0760.jpg
<meta content="text/html; charset=utf-8" http-equiv="CONTENT-TYPE" /><title></title><meta content="OpenOffice.org 3.2 (Win32)" name="GENERATOR" /><style type="text/css"> </style>
Old 10-29-2010, 04:16 AM
simonfly
Have you seen the pics?
What do you think about?
Old 10-29-2010, 09:51 AM
wyo69cowboy
Looks good. How did it turn out for weight compared to the electric setup? Did ya try any different props yet? Keep us posted...
Old 10-31-2010, 07:04 AM
kerwin50
Does she 3d
Sure seems cheaper than going electric
I've wondered how an os 25 would power it
Old 03-11-2011, 10:42 AM
simonfly
ORIGINAL: simonfly
Thanks a lot
The best propeller is APC 11 x 5
Fuel: 20% nitro, 20% synthetic lubricant , 60% methyl alcohol
With OS engine it weighs 1200 grams.
As I have installed engine closer to firewall than electric motor, does the center of gravity move backward? How can I see if the CG is in the right position?
Thank you
Simonfly
Old 03-21-2011, 06:41 PM
kerwin50
What OS engine?
I'm sure alot of guys would love to see this thread in the electric to glow conversion.
I just accidently discovered your thread
Old 04-03-2011, 12:12 PM
simonfly
I have a problem: when the engine stops in flight, the model goes down vertical fastly like a brick.
Could you help me to solve the problem?
Thank you.
Simonfly
Could you suggest a spinner suitable for APC 14x4W and Saito .91?
Thanks a lot
Old 04-07-2011, 07:39 AM
kerwin50
Are you nose heavy.
But why does the motor quit in flight.
need more info
Old 04-07-2011, 12:12 PM
simonfly
I lost idle screw and spring.
The plane should not be nose heavy because, when I fly inverted, it climbs up.
The model is too nervous.
It's too exhausting to fly it.
Simonfly
