Reload this Page >
frenzy and ST90
frenzy and ST90
Old 12-03-2010, 09:29 PM
dschroeder
My Feedback: (40)
Default frenzy and ST90
I picked up a frenzy 100, would a ST 90 fly it decent? I'm not into real "hardcore" 3d basically going to fly it as a sport aerobatic ship. I have a few profiles for serious 3d
Old 12-04-2010, 01:42 AM
ScottMcM
My Feedback: (66)
Default RE: frenzy and ST90
I once had a Frenzy.....loved that plane......anyway, had an OS 91FX in the nose. Plenty of power. Eventually changed it to a Magnum 120 4-stroke.....gobs of torque. Stupidity (mine) killed the plane. Hope to get another one day.
Old 12-04-2010, 08:29 PM
dschroeder
My Feedback: (40)
i was thinking about side mounting the engine...just never had much luck with inverted 2 strokes
Old 12-05-2010, 03:14 AM
ScottMcM
My Feedback: (66)
B oth engines in my Frenzy were inverted. Had a little trouble to begin with with flooding, but nothing major. Once I got them set up correctly, I never once worried about either of them deadsticking......and they never did.
Old 12-05-2010, 09:52 AM
dschroeder
My Feedback: (40)
cool....what prop did you run on the os 91 2-stroke...wasn't sure what a good starting point would be for that plane...i'm assuming the recommended props have too much pitch they recommend a 13x6 for the ST 90. I was thinking maybe a 14x4 APC??
also, what servos did you end up using on yours? i was thinking hitec 645MG on all surfaces
Old 12-05-2010, 01:07 PM
ScottMcM
My Feedback: (66)
It has been a while, but I think I did use a 13x6 prop.....seldom do I attempt 3D. I used high torque servos on all control surfaces except the throttle.
Old 12-06-2010, 02:46 PM
Jezmo
Jezmo's Avatar
I've run both a 13X6 and a 14X6 on my ST90. Which one you wind up using depends on your particular tastes and exactly what you like to do. Mine seems to pull out of a hover better with the 14X6 but does snaps and waterfalls etc better with the 13X6. I assume that's because the 13" prop has a little less gyro effect. I could be wrong but it seemed to rotate quicker with the 13" prop.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
