Smoke System Question
My Feedback: (24)
CA
I am asking this question here because I know a lot of you use smoke on your 3D planes. What type of fluid do you use for smoke? I heard of diesel fuel.....or is there better fluid for it? Also I am running a YS FZ110 with just the header (no muffler), so where in the header should I put the nipple, close to head, middle or close to the end?
My Feedback: (9)
The closer to the head the better. I don't know how much smoke you will get though with out a muffler to slow it down. The diesel needs to be mixed with ATF, One part ATF to 3 parts diesel. Smoke oil bought at the LHS is much cleaner and makes better smoke IMHO but cost 4 times as much.
David
David
My Feedback: (9)
The late great Minnflyer has an article here onRCU called " Got Smoke". There is a lot of good help there. You might search for it. Might even be in the video section. If you can't find it let me know. It's on my laptop somewhere. Also on a plane in the 1.20 size I would mount everything on a ply tray held in with four screws. I say this because the plane will fly SOOO much better without the extra pound. I think you will leave it out most of the time when you feel the difference.
David
David
My Feedback: (9)
Zach is right to a point. A smoke system on a larger glow motor can be done succesfully but it is not as easy as doing one on a gasser where the exhaust temps are higher. I have done one a 1.20 Webra 2 stroke though so I know it "can" be done. The smoke is not as heavy as a good system on a gasser, but it's not bad.
david
david
Smoke fluid is expensive but that is what I use. I have done the diesel fuel thing before but it is kind of greyish and doesn't linger very well. What does linger is the smell of diesel. It smells bad. i mean really bad.
I'll pay 4 times the price for better smoke and less stench.
I have used Super-dri and Robart. The Robart is a little cheaper, maybe a little.
BC, CANADA
If its on a sport plane the smoke trail will be faint, not much more than the smoke trail from the fuel exhaust. The small aircraft and speed make for poor effect.
There are some smoke mufflers available, which pre heat, but the results will be nothing like you see in the videos. from larger gas engines.
My Feedback: (9)
It is also possible to pre heat the oil by wrapping a copper tube around the cylinder head a few times. Then hold it in place with a hose clamp. If you read Minnflyers article I posted above though he does not suggest it. I did preheat the oil on the Webra 1.20 i mentioned earlier. I never tried it without the pre heat to see the difference. My guess would be it would be hard to detect a difference in the air. I just cant say for sure but Mike was right most of the time.
david
david
