 Sig Mayhem 3D ARF >
Sig Mayhem 3D ARF
Sig Mayhem 3D ARF
Old 10-07-2008, 12:49 AM
  #1076
Default RE: Sig Mayhem 3D ARF
i have it installed and almost ready to go mounted ignition same as yours batt in same place a little nose heavy as is ran engine in spins 18x6 wood at 7500 will be very unlimited all yp weight only 250 grams more than glow will fly soon
Old 10-12-2008, 10:50 AM
  #1077
I have tried reading through this thread. I have bought a used Mayhem 90. It is one of the older ones. I noticed that the original engine was mounted over to the left side of the fire wall. I have heard that the fire wall was marked wrong on some of the first ones. Does anyone have any info on the proper engine mounting. I plan on useing a ST 90 with pits that I have laying around.
Thanks john
Old 10-12-2008, 12:50 PM
  #1078
My Feedback: (22)
jship the 90 will pull it around ok I think but if you get in too trouble it is not enought motor too get it out of trouble.Please keep this in mind when you are flying it with the 90.The motor is off set A little too the left side too counter fore the right tork builted in the fire wall.I have one that is about 3 years old and I love it when I fly it.I have A Saito 150 on mine.Hope this helps and good luck.
Joe
Old 10-13-2008, 01:44 PM
  #1079
Last year, at about this time I purchased a used, Sig Mayhem. I bought it sight unseen, which is not a good idea most of the time. It set around for almost a year here, and yesterday I was looking for something to do and there it was.
I got it down and removed the cowl. It had been setup for a Saito 125A. I removed the mounts and guessed at were they were supposed to be and replaced with a new motor mount.
I have a ST 90 laying round now due to the death of My beloved Four Star 60 BIY. I have mounted the engine and re cut the cowl for the ST 90 mounted side ways. I don’t think it looks to bad mounted like this.
When I took the head off of the ST 90 I noticed that there was a lot of carbon built up on the top of the piston. Since it will probably be next year before I fly it I am going to tear down the engine and remove the built up carbon.
john
ID:	1050973   Click image for larger version
ID:	1050974   Click image for larger version
ID:	1050975   Click image for larger version
ID:	1050976   Click image for larger version
Old 10-17-2008, 05:16 PM
  #1080
jship ive flown mahem on st 90 and 1.08 good flying but not great if your going to 3d it hav finished install of 26cc gas engine and test flew today it was crazy power hoverd on 1/4 thottle and still running in so hav room for more power .
ID:	1053785   Click image for larger version
Old 10-18-2008, 12:10 AM
  #1081
The biggest thing I was concerned about was weight. With the light frame, I was afraid that it would not take the weight of a gas engine.
John
Old 10-18-2008, 02:33 AM
  #1082
four more flights today walbro carb tricky to tune .i havnt added any dead weight to my mayem have batt and rudder servo in the tail . only using 250ml tank .was twice that with nitro gussler 10 minute flights easy. motor 900g ignition 100g batt 70g.holding together so far.hav read on this thread of 180 saito on a mayhem.my mvvs is now spinning garvon 18x6 wood prop 7600 with pitts inverted muffler
Old 10-18-2008, 11:13 AM
  #1083
Old 10-18-2008, 11:22 AM
  #1084
I am continuing on. I have installed the Pits and if You notice I have collapsed one of the two pipes on the muffler. This is to raise fuel tank pressure. The last time I used the pits I did not get consistent runs. Next reinstall the cowl and check the fit.
ID:	1054209   Click image for larger version
ID:	1054210   Click image for larger version
Old 11-03-2008, 01:17 PM
  #1085
I just read through a 1081 posts on this thread. I ordered the 40 size Mayhem last week and it is scheduled to be delivered today. I hope it flies as well as its big brother.
Old 11-03-2008, 05:29 PM
  #1086
Jezmo's Avatar
Mine is a blast but needs more power so the MVVS looks like an awesome mod. I just happen to have a 26 IFS Redhead laying around. Thanks for the idea.
Old 11-09-2008, 04:03 PM
  #1087
First post...the mayhem 3d will be my second plane and have read that on low rates, it flies as good or better than a trainer. It should be here at the end of next week but just wanted to get a few set-up details given my current skill and components I have available to assemble it.
I have a Futabs 9cap radio, 5 s3010 servos, approx (90oz) of torque, an OS FS .81a engine from my first plane, a 14x6 KSeries Master airscrew prop, and a 6 volt 1450 mah NimH battery. Also, I'm located in northern Ontario at aprox 700ft above sea level. I don't plan to do 3d right away of course, but wanted to set-up the rudder servo in the tail as suggested in previous posts so that when I do progress, all I would have to do is upgrade the engine to YS 1.10, begin moving the CG aft and increase the control rates, and maybe stronger servos for the evelator and rudder.
One of my concerns was that the OS FS .81a engine only weighs 19.63 oz or 556 grams. and thought that moving the rudder servo into the tail might make it too heavy in the tail end? Also would this be enough power to get the mayhem off the ground and fly mild aerobatics...lops and rolls?
Any thoughts or comments about how to best set-up this plane with the current parts available would be greatly appreciated,
thanks in advance,
Trev77
Old 11-09-2008, 09:42 PM
  #1088
My Feedback: (22)
Trev77 are you getting A 40 size or A 90 size? The 81 is ok for the 40 size.I have A 90 and I have A Saito 150 in mine and it will do any thing A good polit ask of it. I can't fly 3D but I have A buddy that can fly my Mayham 3D.I am running all 126 jr steel gear servos on all my elev rudder and aillrons.I set my plane up like the book called for and it balance with the bat and no extra lead. If you can aford it you would be better off going ahead and upgrade too the bigger motor and servos now and you wouldn't have too recut you cowl.The YS110 would do you better the the 81 all thro it dont take much motor too fly this plan but if you get intoo A pickle the 81 might not have enought too pull it out.Only my thought on it and hope this helps and good luck.
Joe
Old 11-09-2008, 11:04 PM
  #1089
Thanks Grandad1 for your reply. I ordered the .90 size mayhem. I'll just wait until I can get a bigger engine and metal gear high torque servos before final assembly. I thought of the 40 size but like the bigger airframes, plus I hear it comes with pretty good hardware, apart from the axles. The snow is starting to fly here and might set it up with some skis as well. Anyone put skis on the mayhem yet?
thanks again,
Trev
Old 11-09-2008, 11:26 PM
  #1090
I put skis on my Mayhem 40 last year and will have to again soon, we already have snow here as well. Didn't hardly notice them and they worked perfectly.
Old 11-09-2008, 11:55 PM
  #1091
Still need a bit more snow here for skis but if it's anything like last winter...won't be long! What were the dimensions of the skis you used on the 40 size. Would probably need to add a few inches for the 90 size I'm guessing?
Old 11-10-2008, 10:03 AM
  #1092
I use these,
http://www.shopatron.com/product/par...161.5192.0.0.0
They say they work on up to .60 size airplanes, but what type of snow do you fly off? They worked fine for taking off of the light, fluffy powder and were almost not needed when are runway was packed.
Old 11-10-2008, 11:09 AM
  #1093
Thanks for the link Squeaky Penguin. Unfortunately, our field access isn't plowed during the winter months. This will be my first winter flying, so when the lakes freeze over for ice fishing I plan to do both. Many of the lakes see very little activity during winter and the snow is generally fluffy powder, unless a cold wind after a thaw has been at it, then it can form a nice pack. Since it will be a tail dragger, did you use the same large ski on the rear as well?
Old 11-10-2008, 04:28 PM
  #1094
I've though about taking a plane ice fishing as well, sounds like a good combo; fishing and flying. Only up in Ontario you get to catch walleye I'm sure, I get tired of seeing trout. I don't use a ski on the back. It has no problem staying up when the field is packed, and when it isn't it just sinks a little bit and the tail floats on the light snow.
Old 11-11-2008, 12:36 AM
  #1095
There are lots of lakes with walley...one of the favourites for many, and on the top of my list. So when the fish are not on...I'll be flying the Mayhem...should be fun. Thanks for the tips regarding the skis. like I said, this will be my first winter flying, so all the help is appreciated. Now just have to wait until the plane arrives to start assembly...can't wait.
Old 11-11-2008, 01:01 AM
  #1096
Forgot to ask....did yopu keep the tail wheel on or take it right off for winter? Oh ya, on a trout note, there harder to come by here. What kind do you get down in Colorado? Probably should start a new post on the subject....brings a whole new meaning to fly fishing. lol
Old 11-11-2008, 06:12 PM
  #1097
I kept the tail wheel on. I don't know if it really matters though. Here in Colorado we catch Brooke, Rainbow, Cutthroat, and Brown Trout, it just depends on where you fishing.
Old 11-12-2008, 07:51 AM
  #1098
Thanks Squeaky Penguin. I just realized that the 90 size mayhem was a one peice wing. I understand that the 40 size is a two piece which would make it easier for transportation out on the lakes. Wonder if the larger wind could be set-up as a two peice and still remain strong?
Old 11-12-2008, 10:07 AM
  #1099
My Feedback: (17)
My Mayhem 40 was a one piece wing. Also the 90 was.
thanks
Barry
Old 11-12-2008, 05:53 PM
  #1100
chemie's Avatar
Most of the 1000+ posts are on the "big one". What is suggested engine for the 40 size? TH says .4-.46 which seems way silly. A .55? A .61? (2 stroke).
What are the differences between the 60 (or 90?) versus the 40?
Thanks.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
