Extra 260 27% Hangar 9er
#1252
Banned
CA
RE: Extra 260 27% Hangar 9er
do any of you fly electric 3d or all of you gas heads because i used to fly nitro and i never could get the mix right too much air or too much gas whats the secret....
i hate the combustion engine even my 305 gm motor leaks oil
#1253
CA
ORIGINAL: tf2psycho
#1254
TX
lol, took the words out of my mouth.
at any rate, there's a guy here that converted his 260 to electric power. If i have cash to burn, I might do that, but for now, I love my DA50
#1257
CA
ORIGINAL: tf2psycho
ill show you beginner f0ck face
If you can't get an engine to run well, you have learning curve issues to work-out. None of us were born knowing everything...even you. If you have questions about tuning an engine, go to a thread about your engine and ask some people who have the engine you are having trouble with to help you with yours. Why come here and flame me when I'm trying to help you?
Sheesh!
Good luck.
ps: You might want to consider some Anger Management therapy. Good luck with that too.
#1259
CA
On mine, both of the pull-pull wires rub on one of the rear bulkheads. This is even with the wires crossed properly. For those of you not using a gas motor, have you found this to be the case also?
#1260
VA
Yes I think everyone has had issues with the pull pull cables. I went in with a dremel tool and cut a slot in the former for the cables to run through and haven't had a problem. I didn't get a chance to fly mine this weekend the wind was hurricane force it felt like. I will go flying some this week after work though.
#1262
FL
Hey Guys!
I thought I would share this with y'all. My Extra 260/ DA50 is flying great and very happy with this set-up. I feel it is a tad heavy but still, it is a blast to fly. It loves hi-alpha stuff and hovering. I Just got comfortable hovering the thing on the deck!
Last night I was doing some maintenance on it and found that the wing tube sock was loose. I could almost slide the thing all the way out. So I CA'd it back in place and check the fit of the wing tube and found that it had considerable up & down and side to side play. To fix this I used a single layer of trim tape wrapped around the wing tube, especially in the areas where the tube goes in the wing tube sock that is supported by the ply would structure in the fuse. No tape was put on where the wing tube goes in the wings because the fit was still reasonably tight. Everything tight again and ready for the flying field.
Have any of you guys experienced this situation yet?
Happy Hovering!
"I thank GOD for this hobby........I helps me to keep looking towards the skys of Heaven!"
Happy Hovering!
#1263
FL
cstevec
I also had a problem with my rudder breaking at the leading edge where the counter balance meets the rudder. I just peeled back the covering reinforced it with balsawood stock ,CA and recovered it. I do not a "wag" problem as described by others in earlier posts, but I will tell you the rudder in this plane is very week and the balsawood very soft. Out the box the rudder was warped and was able to get it some what straight by heating up the Ultracote. I liked the Idea that you sheeted the whole rudder and I am thinking of ordering a new rudder, or build one from scratch, and sheeting it as well.
#1264
I'v been joggling between a DA50 and a SAITO 180 and from what I read I start beliving that maybe, just maybe, the DA50 is slightly overkill and that the SAITO is more proper for the construction of the plane. (Got mine today and have been ironing the whole afternoon).
A SAITO 220 would probably be more correct, but how many wngines should one buy to get 2x2 meter planes flying properly.
(I'm just a regular flyer, not much into 3D so I think the 180 would do, or, or?????)
#1265
CA
ORIGINAL: krokko
I already have 3D planes with insane power, and I bought this plane specifically for scale aerobatics. The 220 might be the best choice for this airframe, but I cannot comment from a position of first-hand knowledge...so I won't comment at all (at least for a week or so.)
#1266
My Feedback: (26)
WI
ORIGINAL: kolarshooter
So far, I'm with you. Mine's almost done with a Saito 180. I'll certainly get to maiden her within a week's time.
ORIGINAL: krokko
Can you balance this plane without adding lead to the nose with a 34oz motor/muffler?
With the right prop and fuel on a 12 pound plane the 180 should have unlimited vertical. No it won't be breathtaking, but more than enough to fly a BASIC or Sportsman IMAC sequence.
One mans "insane" power is another mans "adequately" powered--It is very subjective.
#1267
TX
to achieve that, you basically have to move the battery to the firewall. PM Matt (theDak) as he seems to be the resident expert when it comes to building light.
#1268
ORIGINAL: Flyin Hawaiian
cstevec
cstevec
I never noticed the "wagging problem people are talking about in this post. As far as I can tell, mine does not do that. I did notice that wind seems to buffet it around quite a bit.
#1269
I weighted everything out of the box today:
total with goodie bags push rods and clevises included: 3680gram = 9.859 pounds, SAITO 180= 880gram = 2.35 pounds
6 servos approx 420grams = 1.12 pounds + receiver, batteries cables I get a total of approx 5500 grams = 14.7 pounds
SAITO 180 still a good choice???
#1270
Krokko, You'll be liter than that complete. I'm at 12.5 with all the same setup. Saito 180, 5645's everywhere. HS 81 thott. "But" I am using a Dura Lite bat setup.
IMO, you won't get over 13 with the Saito 180...... unless they hid a brick in the plane.. The Dak was able to keep under 12 LB w/ the big OS. I don't know how, but he did it, and I bet it flys good.
One thing................ put everything you can toward the nose.
And again IMO "YES" the 180's fine. I would have left mine with the 180 if I did'nt need it for another plane.
Good Luck
Good Luck
#1271
My Feedback: (26)
WI
ORIGINAL: krokko
If your scale is correct @ 9.85 pounds, that is exactly what I was afraid of with this plane. There would be some with dense wood that were heavier. I was thinking about using an OS1.6 and if I started with a 9.85 pound plane I would end up very close to 14.35 pounds. With a 180 or YS160 I would be at 13.75 pounds.
#1272
The scale is absolutely correct! I use a weight watchers scale, you can't get any closer the that! After looking at the build I dont consider putting o a 50cc on any moore. The rudder is too weak, (ref to earlier comments) some of the reinforcements in the wing for the DB pin hinges came loose while I was fitting them. I belive I have to add some CA and Epoxy here and ther to keep the thing together. So,I'll stick with the SAITO 180 and hope it will fly well. I'm a little bit dissapointed! Having put together a GP Patty W and lately a Cuique S Yak-54 72" I think this one is not living up to my expected Q standards. (Not to mention comparison with my Composite-ARF Extra 2.30, but of course the price tag is then much higher).
#1273
My Feedback: (21)
PA
I just balance @ 5 1/4" with an OS 1.60FX and a Bisson BGX Pitts. Anything farther forward forget it. You can't possibly weigh that much. I'm @ 11lbs 13.25ozs AUW. I am using a Li-ion, lightened spinner backplate, Foam wheels and I cut the floor of the hatch out. If you use a NIMH and a regular backplate you might get close to 5" but @ the cost of weight and with a 180 I would definately try to keep it as lite as possible. My pull-pull cables rub the bulkhead too. I dremeled some of the wood away but they still touch slightly.
Matt
Matt
#1274
My Feedback: (26)
WI
ORIGINAL: thedak
Matt
Matt
Krokko, next time you go to the market bring a long a weight that you think is 10 pounds and have them weigh it on their commercial scale.(I think in the USA they have to be calibrated weekly by law) then you will have a good standard to use on your weight watchers scale for around 10 pound measurements.
I have a 2.5,5& 10 pound weight that I had weighed on 2 different commercial scales that I use as standards when I weigh stuff. That way I know for sure my scale is good at 2.5,5,7.5,10,12.5,15 and 17.5 pounds.
#1275
WY, BOLIVIA
HA HA HA THAT IS PRETY COOL THAT I SYARTED THE POST WITH LIKE 1000+ OTHERS POSTS ON THE 260!!!!
OH WELL TOC YAK FOR ME INSTEAD
