 Showtime >
Showtime
Showtime
Old 10-03-2005 | 06:32 AM
  #1001
Default RE: Showtime
Advent,
Thanks for this great tip!
What is the make and model of your incidence meter?
Thanks!
Magoo
Old 10-03-2005 | 09:04 AM
  #1002
Toto's Avatar
My take on the dead spot at low speed is not from the sfg but from the barn door Aileron which when defelected at low speed take away or mess the air flow over the elevator.
I fly mine with a moki 1.35 and go verticle on take off and don't get in that position. Then when landing I turn while losing altitude at the same time to keep speed up that way there is air flow over the tail.
PLus don't deflect Ailerons alot at low speeds.
Hope this will help
Rich
Old 10-03-2005 | 09:07 AM
  #1003
exeter_acres's Avatar
Ok...i've read through.....
someone bottom line it...
Looking for an IMAC/pattern practice plane that I can have fun with....
I already have a Profile Katana for serious silly 3D
Showtime with Saito 100 ok for this??
I know it won't be a rocket, but would it be fun....
I already own the Saito 100 so there is NO OTHER option for the motor... if the motor doesn't work, I get another plane.....
Exeter
Old 10-03-2005 | 09:24 AM
  #1004
tIANci's Avatar
Exeter - a few pages back someone flew theirs on the SA100 ... he was not a happy bunny for sure! But again, thrust/performance is a relative thing. Another plane? Try the Fliton Extra 330 then.
Old 10-03-2005 | 09:37 AM
  #1005
that is the other one I'm looking at.....
the hobby shop has one on order for me (I don't have to buy it though...)
Old 10-03-2005 | 10:58 AM
  #1006
NeoGenesis's Avatar
My Feedback: (27)
I currently fly my ST with a Saito 100. It is a great flier with this combo.....if you plan on flying IMAC routines with it...it's perfect....if you want the punchout power for hovers...it's not there. I fly a little of both, and I enjoy it. If you poing the nose up, it will climb quite a while before giving into gravity, but mine came in a little beefy also. Not sure why, possible a early production plane. I'm not a hovering freak, but like to do the occasional blender, harrier, etc etc etc mixed in with 4 points and all the basic aerobatic manuvers. Get it, with the Saito 1.00, it is a great flying plane.
Neo
Old 10-03-2005 | 12:36 PM
  #1007
MIXMASTER's Avatar
My Feedback: (15)
ITS SO FRUSTRATING!!! I'VE BEEN OUT 3 TIMES W/ST, HAVE ABOUT 20 FLIGHTS, AND STILL ONLY 2 FLIGHTS WITH POWER ON LANDING.(MOKI 135) I CAN AT LEAST SAY THE ST PENETRATES ON DEADSTICK SIMILIAR TO A PATTERN PLANE, BUT NOT AS MUCH SPEED. ITS FRUSTRATING BECAUSE I HAD IT RUNNING LONG ENOUGH(& HIGH ENOUGH) TO FIND OUT IT HARRIERS WELL, NOT MUCH AILERON NEEDED,HOVERS WELL(ADDED MORE RIGHT THRUST) AND TRACKS BEAUTIFUL POINT ROLLS,FLAT SPINS ARE FLAT.
LOOKS LIKE A COMPLETE 3-D(I HAVENT FIGURED OUT WHAT 4-D IS YET)MACHINE, BETTER THAN THE EF YAK. I JUST NEED TO GET THE MOKI STRAIGHT TO BUILD CONFIDENCE. I STILL HAVE NOT EXPERIENCED THAT PROBLEM SINKING ON TAKE OFF, I USED TO LIKE DOING POINT ROLLS ON TAKE OFF WITH OTHER PLANES BUT AFTER READING THIS PAGE I WILL HOLD OFF ON THAT UNTIL I KNOW MORE ABOUT THAT PROBLEM. IVE DONE 4 POINTS HIGH WITH IT, DIDNT NOTICE ANYTHING THERE, MY SPEED WAS PRETTY HIGH COMPARED TO TAKE OFF THOUGH. I DID NOTICE A CHANGE IN FLIGHT CHARACTERISTICS AFTER INCREASING PITCH OF THE PROP, I WENT FROM A 17X5 ZINGER TO 17X6 TOPFLITE, THE ST WAS FLYING WITH A NOSE UP ATTITUDE BEFORE THAT. LIKE IT WAS TAIL HEAVY BUT IT IS ON STOCK CG. THAT WAS A LITTLE ODD, NEVER HAD A PLANE DO THAT.
Old 10-03-2005 | 02:55 PM
  #1008
raideron's Avatar
WHAT...... Sorry I had to do it
Old 10-03-2005 | 04:29 PM
  #1009
drumbum's Avatar
ORIGINAL: MIXMASTER
alot of people including me. think it has a tail heavy feel at stock CG. I even saw on the competitons forum were Kyle said it felt that way to him too..
Old 10-03-2005 | 09:16 PM
  #1010
kregan's Avatar
I use a laser meter from Great Plains I think...
ORIGINAL: LarryMagoo
Advent,
Thanks!
Magoo
Old 10-03-2005 | 09:19 PM
  #1011
kregan's Avatar
If you jump over to the Pattern forum there is a thread on the showtime
for pattern flying with some setup tips from some very knowledgeable pattern
fliers.
ORIGINAL: exeter_acres
Old 10-03-2005 | 11:45 PM
  #1012
DiscoWings's Avatar
My Feedback: (76)
Saw this SHOWTIME the other day at our local club.
Juding from what I saw... I can easily say that the engine to go with is the SuperTigre 2300
Man that engine gave this plane some power
Old 10-04-2005 | 09:23 PM
  #1013
Advent,
fliers.
DO YOU HAVE THE LINK FOR THAT?
It's not that I'm too lazy to look for it.......okay.. ..maybe I am....
Magoo
Old 10-05-2005 | 12:12 AM
  #1014
Nickolas's Avatar
Here is the link of the Pattern Flying Forum:
http://www.rcuniverse.com/forum/m_3329224/tm.htm
Old 10-05-2005 | 03:06 PM
  #1015
My Feedback: (12)
Does anyone know the diameter of the Showtime wingtube? I have one on order, but I want to get an carbon fiber tube. I can get metric or inch tubes, so if it doesn't measure evenly on one scale, please try the other.
Thanks.
Jon Lowe
Old 10-05-2005 | 03:37 PM
  #1016
My Feedback: (17)
It's either 1" or 1 1/16" The way I measure mine it's 1 1/16".
Barry
Old 10-05-2005 | 07:58 PM
  #1017
My Feedback: (22)
Jon,
Let me know if you find a carbon fiber wingtube.
I can't seem to find one that is the correct size.
It would need to be 1 and 1/16" or 26.9?mm (so call it 27 mm).
As good as this plane is, this is one of the things that could be done to improve it.
I also think that the SFG's should be molded from carbon fiber also.
Heck it would be nice if the plane were ALL composite and 2X2 meter in size.
Oh well, I guess I can dream.
I personally think this is one of the BEST ARF's I have ever seen.
It also flies best with the SFG's, IMO.
Barry Finck
Enola, PA
Old 10-05-2005 | 09:41 PM
  #1018
SPUD37's Avatar
Hey Guys,
SPUD here-got my first 2 flights in today. Winds were across the field at about 15 mph. So just out to get a feel for the plane. No trim needed, but then again to get it set just right I'll have to wait for a calmer day. Sat there and messed with the engine, didn't refuel, so the first landing was dead sticked. This thing lands as smooth as the UCD's. Rock steady all the way down. No tip stall tedances on mine at all. Second flight landed with power and it was great. Being larger it was easy to see all of its moves, this is a fun plane to watch fly. Did some rolls, up & inv spins. With my snaps I need to dial the ail down a smidge on low rates to clean them up a bit. This is going to be one of my favorites.
My set up is:
OS 120 4C
Hitec 635's on ail & ele
Hitec 625 on rud
Fut 3004 on thr
CG 7 3/8"
rud servo in tail
3" main wheels
Fut 9cap
Stock on everything else.
Well thats it till Sunday.
SPUDs out.............see ya.
Old 10-06-2005 | 12:08 AM
  #1019
My Feedback: (17)
Spud...Congratulations on getting that bird in the air!!! I find this plane to land very good, even in the wind. Not at all like my Funtana was. Great flying airplane. Hope you like yours as much as I do mine.
Barry
Old 10-07-2005 | 07:00 PM
  #1020
Nickolas,
Thanks for that Link to the pattern thread!!
PS I appologize for spelling Monocoat....Momocoat....should have used spell check!
There is some great stuff there!
Keep the rubber side down!
Magoo
Old 10-07-2005 | 07:09 PM
  #1021
kregan's Avatar
Another heads up...
On my Showtime the fuel tank comes in contect with the upper right
motor mount bolt. this could lead to a hole rubbed in the tank if it
goes unnoticed.
Old 10-07-2005 | 07:20 PM
  #1022
drumbum's Avatar
Nickolas,
Magoo
Monokote
Old 10-07-2005 | 08:03 PM
  #1023
DrumBum,
Can you believe that??????????.... I knew it was spelled ...kote....I was so focused on putting the M in there instead of the N that just I just finished the word with brain out of gear
Thanks!!!
Old 10-09-2005 | 12:09 AM
  #1024
AirWizard's Avatar
I maiden my Showtime with YS 110 today.........I'm impressed. Looks like my Extra 260 will be getting a much needed rest.
Old 10-09-2005 | 05:18 AM
  #1025
My Feedback: (17)
dgeorge...Congratulations on a successful maiden flight! Really cool airplanes.
Thansk
Barry
