Reload this Page >
Great Planes 25% Yak 81" 12-lb, seen on Fly3D Magazine
Old 11-17-2006, 10:09 AM
  #526
gasguy
My Feedback: (13)
gasguy's Avatar
Default RE: Great Planes 25% Yak 81" 12-lb, seen on Fly3D Magazine
[/quote]
So, one of these:
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJUN6&P=Z]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJUN6&P=Z[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV48&P=]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFV48&P=[/link]
[/quote]
Go with the first one if your field is rough or stay with original if field is smooth or paved. Here its rough with a few crevasses that took off my tail wheel on a GP Stearman, so most of my planes get this mod. You will have to make a ply plate for bottom opening, but this makes it easy to epoxy the horiz stab and to install the pull-pull wires.
Also one of these:
[link]http://brillelli.com/brillelli_engines_009.htm[/link]
Get option2. The average person just can't build one from scratch for that price and do all the work Brillelli puts into it. The service from Brillelli is first class. Scott just modified my 46 a few weeks ago for free, 'cause asked him, !QUOT!wear to put the pressure smoke port.!QUOT! He said it should of had one, returned it and several modifications were done, what a class company. I missed out on the Bowman ring, darn. Also get the rear dump muffler, side or rear your choice. He has a lighter rear dump muffler coming, not sure the cost or if its free with purchase.
This is my second gasser (GP Stearman w/33 Homey, first) and at $2 a gal vs $12 to $18 for glow, with flight times up 1/2hr on 16oz. of gas, whats not to like. Go gas you'll never turn back.
Also smoke system for $11 less tank:
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD625&P=7[/link]
The CG is conservative as Uncas said, and I may end up with no lead up front after testing with 5oz. My Yak was purchased a few months ago and like a few post back the wood or styrofoam my be a little heavier than the older lots.
glowguy
Old 11-19-2006, 11:29 AM
  #527
The MacDaddy
My Feedback: (10)
The MacDaddy's Avatar
Hey guys, looking for some direction, pics would be greatly appreciated. I have a DA50, Fromeco's w/ Regulators. Where is the best place to mount the batteries/regs/switches and Ignition???
What kind of switches are you all using? MPI? Cermark?
Mac
Old 11-19-2006, 06:50 PM
  #528
tazlittleking
ORIGINAL: The MacDaddy
Mac
My buddy and I are building exactly the same. He has already finished and flying. This is how his is set up and mine will also be the same. We are using 2 Cermark switches one for each battery, to a batshare, to a regulator, and then receiver.
He found some good light black rubbery foam to wrap them in also.
ID:	563289   Click image for larger version
Old 11-19-2006, 07:42 PM
  #529
The MacDaddy
My Feedback: (10)
Taz,
What does your ignition look like? You really got that s*hit in there tight... nice work bro.
Mac
Old 11-19-2006, 10:48 PM
  #530
tazlittleking
I have bought the same setup just not built yet. This is my buddy's setup. His screen name is charlesdanni on here. This plane is sweet with the DA-50. Just now going into it's 4th gallon of gas and it hovers at half throttle with ease!
Here is some pics he passed on to me of the ignition and front area
ID:	563469   Click image for larger version
ID:	563470   Click image for larger version
ID:	563471   Click image for larger version
ID:	563472   Click image for larger version
Old 11-20-2006, 07:39 AM
  #531
The MacDaddy
My Feedback: (10)
Thanks Taz, that will really help out. I see your buddy ditched the cowl ring mounting system. The ignition gets in the way of the left side blind nut, it would need to be moved. Are you going to put the muffler support bracket on? I couldn't figure out how it mounted until I saw a pic, the one end goes under one of the cylinder bolts...... I questioned if you need to replace the bolt w/a longer one? I was fiddling w/ the cowl last nite, there's a bunch of cyl/muffler sticking out.... I'm guessing the whole bottom of the cowl is going to be cut out?
Mac
Old 11-20-2006, 09:03 AM
  #532
tazlittleking
Mac
He did cut good amount at bottom, but it came out very nice.
ID:	563638   Click image for larger version
ID:	563639   Click image for larger version
Old 11-20-2006, 02:17 PM
  #533
Tesla1856
Tesla1856's Avatar
Taz,
Thanks for the pics ... It looks really good. I think I'm also going to get the DA-50 for my new Yak 54.
Are those 3 inch stand-offs, and the Slimline SLI-2123 muffler?
Old 11-20-2006, 06:44 PM
  #534
tazlittleking
ORIGINAL: Tesla1856
Yes and yes
Old 11-20-2006, 07:39 PM
  #535
BMiracleTX
Does anyone know where to get a wing tube[X(]
I was coming in low inverted when I got "glitched" and ended up doing a knife edge plow on the field...somehow I managed to save it. The right wingtip hit the ground in a full knife edge, sheared off the wingtip and aileron counter balance, and snapped the aileron control horn...I somehow managed to not wreck it, limped it around and landed with that big heavy fat aileron drooping!!
Anyways, I fixed the wing (actually a really easy fix) but then noticed the wing wouldn't line up right....the wing tube is bent! I also somehow bent the tube during all of that! Surprisingly, it didn't damage the fuse or wing any further!
Long story short....now I need a wing tube! Since GP doesn't sell them...any ideas on an aftermarket one? Has anyone bought one yet? If so, please advise!
Old 11-20-2006, 07:41 PM
  #536
BMiracleTX
Oh yeah....here is the damage and the fix!
ID:	563904   Click image for larger version
ID:	563905   Click image for larger version
Old 11-20-2006, 09:47 PM
  #537
BMiracleTX
Please disregard! I overlooked the part number at Tower! Thank you to fly3dnyc for PM'ing me the part number! For anyone else who may run into this in the future:
Great Planes Wing Joiner Tube Yak 54 1.60 ARF
Special Stock#
LXNUW7
Tower's Low Price
11.49
Old 11-21-2006, 03:04 AM
  #538
Tesla1856
Tesla1856's Avatar
Nice job on the wing fix ... looks really good.
Old 11-22-2006, 06:23 PM
  #539
evfast
My Feedback: (31)
evfast's Avatar
I have this plane with a DA-50 and would like to install a smoke system. So any advice on pump what size tank and how to set up would be great.
Old 11-22-2006, 07:51 PM
  #540
cfossa
Does this plane fly anything like the Yak on RealFLight G3? I so, it must be a blast.
Carl
Old 11-23-2006, 01:34 PM
  #541
evfast
My Feedback: (31)
evfast's Avatar
In my opinion YES!
Old 11-23-2006, 01:48 PM
  #542
cfossa
Might need to be my next plane then
I've got tthe GP Gene Soucy Extra 1.60 with an OS 1.60 FX. FLies great, but not a 3D monster. The YAK seems to be a much better 3D plane.
Carl
Old 11-25-2006, 10:32 PM
  #543
dunaman
Here is my Yak 54 with the new CAR 55, a really great Brazilian engine, 5.5 hp of pure brute power. Well.......the OS 160 didn´t did the job!
Now I have the right engine for the right plane.
ID:	566674   Click image for larger version
ID:	566675   Click image for larger version
ID:	566676   Click image for larger version
ID:	566677   Click image for larger version
ID:	566678   Click image for larger version
Old 11-25-2006, 10:35 PM
  #544
dunaman
ooops....sorry for the feet.....hahahaha
Old 11-26-2006, 12:02 AM
  #545
jon595
Anybody have a set of undamaged wheel pants they want to get rid of? Send me a PM if you do.
TIA,
jon
Old 11-26-2006, 02:27 AM
  #546
Barry Cazier
My Feedback: (17)
Are the wheel pants the same ones supplied on the CAP? If they are I probably have a set for you.
Barry
Old 11-26-2006, 05:53 AM
  #547
dunaman
Jon, You can find the originals at [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLLB8&P=Z[/link]
Old 11-26-2006, 08:30 AM
  #548
dunaman
Old 11-26-2006, 11:42 AM
  #549
jon595
I saw where I could get them from Tower, however some people do not put these on and I would rather put the green in their pocket, not the evil empires!
They are more like spats, not realy typical wheel pants.
Old 11-26-2006, 12:49 PM
  #550
dunaman
Ok, good lucky!
