Reload this Page >
Great Planes 25% Yak 81" 12-lb, seen on Fly3D Magazine
Old 04-19-2007, 06:29 AM
  #651
Corwin38
Default RE: Great Planes 25% Yak 81" 12-lb, seen on Fly3D Magazine
Has anyone had any trouble with this landing gear? I had a rough landing yesterday and cracked the frame. Just wondering how I could reinforce it without opening up the bottom.
Old 04-19-2007, 07:21 AM
  #652
Corwin38
Here is a photo. The screw to the right popped loose (or rather the blind nut pulled through the ply).
Old 04-19-2007, 07:26 AM
  #653
Bob Pastorello
My Feedback: (198)
Bob Pastorello's Avatar
Mine is supposed to arrive tomorrow, and I've been reviewing this thread since the beginning. FINALLY getting one.....anyway, a couple pages back I think there's a pic of a guy that put a ply doubler on TOP of the landing gear mounting ears inside the fuse, then drilled through that whole assembly to make a sandwich, if you will. I've done similar in the past, but have learned that making the gear block "too" strong really just ensures irreparable and severe damage with those "hard landings". There's a point of diminishing return building in strength....
I'll be following this closely, and looking at it hard when I assemble mine.
ORIGINAL: Corwin38
Old 04-28-2007, 11:25 AM
  #654
walterPPK
walterPPK's Avatar
Damn!... Just finished reading this whole thread!...
I have a YAK-54 and a DA50 at home, will start building tonight and will document all the work I do with my camera to post a complete construction sequence.
Thanks for the info.
Old 04-28-2007, 09:09 PM
  #655
Ialwayscrash
My Feedback: (106)
Ialwayscrash's Avatar
I reinforced mine before the first flight and have had no trouble at all with it. I fly off of ROUGH grass fields that are used for other purposes and thought that it might not be strong enough. I do not have a better picture so here goes. I hope you can make it out.[img][/img]
ID:	674271   Click image for larger version
Old 04-30-2007, 10:59 PM
  #656
boex
I am contemplating the move to a gasser class plane like the gp yak54. I currently fly electric and glow. However, I was reading on rc groups a disturbing comment about the flight characteristics of the yak by none other than Jason Noll.
Here is the link http://www.rcgroups.com/forums/showt...ight=gp+yak+54
What do you guys think?
Old 05-01-2007, 12:50 AM
  #657
Tesla1856
Tesla1856's Avatar
Looks good.
About how thick is that large piece of ply, and is it glued to the side braces you installed.
ORIGINAL: Ialwayscrash
Old 05-06-2007, 09:51 AM
  #658
doublesixes
Yeah, what's with this plane? I was thinking about getting one myself but I'd like to hear some comments from pilots actually doing serious 3d with the bird before committing.
Old 05-06-2007, 08:36 PM
  #659
flyman1948
med601
I have had trouble range checking the plane with motor on. Could not get 90 feet with antenna colapsed (per Futaba instructions) or 150 feet with one section antenna extended without serious glitching. Replaced PCM with a PPM/FM reciever..more problems became evident. I pulled the battery out of the plane, pulled the recievers as far to the rear as I could with the cables, and repositioned the antenna outside the fuse. Still would not pass range check. Friday I bought a DX-7 w/7000 reciever...still setting it up.
balance: tried to mount four servos in tail....too tail heavy so went with single rudder servo midship..have balance almost to where GP says to start at.
I also had a hard time starting 2.4 but found that Dubro fuel filter o-ring was not seated correctly.
Old 05-07-2007, 09:09 PM
  #660
fingers73
fingers73's Avatar
My yak balances on the aft most cg, I think that is something like 5 and 5/8 inches. It is perfect almost no input needed for inverted flight. It has no adverse effect on flight, lands like a dream. all my servos are in the tail, but only one rudder servo. It flys imac and 3d awsome. My only complaint is it flys to lite weight in higher winds.
Old 05-08-2007, 08:30 PM
  #661
mwhar760
My Feedback: (18)
mwhar760's Avatar
is the spark wire grounded/shielded ect. are you running a bosch type plug cover do you run noise suppressors on your servo leads,what radio are you running,engine combo how close is your ign. battery to the reciever, and ect.i have run gassers on and off for years and have never had this problem even with the magnito ignition maybe i can help you before you spend all that money on the dx7
Old 05-10-2007, 06:10 PM
  #662
mwhar760
My Feedback: (18)
mwhar760's Avatar
i'm wondering if anyone here has used the thor 45cc? i recently aquired one and wanted some input. i'm planning on putting it on mine.
Old 05-19-2007, 10:02 AM
  #663
med601
Flyman1948,
Hope you managed to solve all your problems with radio interference.
I had the same problems when istalling my 2.4 FPE into a sig extra 300sx, turned out to be the Ridge ignition, which comes as standard on the 2.4. after replacement all was fine.
I'm curious how the 2.4 will fly the yak. I just recieved a DL50 (chinese version of DA 50 ) great engine! swings 22x8 / 23x8 props same weight. half the price. Not sure which one to install.
Question: If i am installing pull pull on the rudder single servo mid ship, can I use the rudder servo hole cutouts in the tail for my elavator? The only reason I want to do this is that it looks neater and the linkage is shorter. is there any reason why I couldn't ?
Old 06-10-2007, 12:29 PM
  #664
med601
I have not been very active with regards to building my yak. I'm still undecided as to which engine to use.
Flyman1948, have you flown yours yet? I would love to here how she flys with the fpe 2.4
Old 06-22-2007, 11:12 PM
  #665
Uncas
Has any tried this plane with a MOKI 2.10?
Old 06-28-2007, 10:06 PM
  #666
dirtrider250
ok i got a question here, i just bought a great planes yak 54 and i put a da 50 on it and for some reason it balances way TAIL heavy, can anyone tell me what im suppost to do or if anyone has built one of these with a similar motor what im suppost to do
thanks
mark
Old 06-28-2007, 10:24 PM
  #667
med601
I'm also using a similar engine ( DL 50cc ) same weight , power and style as the DA but half the price.
I used 3'' stand off. I put a single servo in the fuse for rudder (pull pull)
That's as far as I've got , not sure where that will put me in terms of balance.
Old 06-28-2007, 10:26 PM
  #668
med601
Mark,
By how much is it tail heavy?
Med.
Old 06-28-2007, 10:34 PM
  #669
med601
Flyman,
What's happening are you flying yet?
I want some feed back, please!
Med
Old 06-28-2007, 11:42 PM
  #670
dirtrider250
i dont im scared to add weight, it feels liek it nees an engine that weighs like 2 poudns more , i thought a da 50 would be a nice match but GP says to use a fuji 43 or a 160 2 stroke glow, and i cant see how u cna get this thing to balance with a 160 glow thats for sure and a fuji only weights 8 ounces more then a da50. i know i have 4 servos in the tail section 2 elevator and 2 rudder HELP !!!!!
Old 06-28-2007, 11:55 PM
  #671
tazlittleking
Mine is a DA50 also: 3" standoffs, go pull pull with your rudder servo(s)
It was right on for me.
Old 06-29-2007, 12:05 AM
  #672
dirtrider250
aww crap i already put them in now ill have two holds in the body. , i might me making a pile of crap out of a fart but the plane balances about 6.5 inches behind the leading edge, instedad of the manuals 5 1/8 i dont not know if thats a huge big deal but i dont even think if i took out both rudder servos out that it might matter, but i can give it a shot and take the two rudder servos out and see how it balances then. thanks
Old 06-29-2007, 12:50 AM
  #673
Tesla1856
Tesla1856's Avatar
Where did you buy your DL 50 ?
Sounds interesting and I still need an engine for my GP Yak 54.
Old 06-29-2007, 07:04 AM
  #674
med601
www.dlusa.net
Old 06-29-2007, 07:17 AM
  #675
747-RCU
My Feedback: (22)
DirtRider250,
I have a DA50 in mine as well. I have 3 servos in the tail, 2 elev and one rudder. Recvr right at the end of canopy in the fuse where rudder pull/pull config servo bay is. Fuel tank is 16 oz.
At first, I used 2.5 inch standoffs as the original builder had, and I was tail heavy. I had to put 2 huge nicd packs in the engine box to balance. Then I had a mishap and rebuild the firewall, and this time, I went with the manual and measure the back of spinner plate to firewal distance as 7 1/8 and the engine was brought about 3/4 of inches forward. This helped tremendously. Now I have only a 4 cell AA pack in the engine box for ignition and my recvr pack 5AA is in the fuse behind the wing tube.
You can put some spacers on the firewall with the standoffs and bring the engine forward and remove one servo from the tail for rudder, I used a 5955, 300oz, that cust the weight of one servo in the tail. Your difference in the CG is too much, GP's recommended CG is too conservative, plane flies better at around 5 and 3/4. Hope that helps.
