Funtana X100
#3652
RE: Funtana X100
ORIGINAL: bryant.law
I have a CRRC PRO 26cc gasser and I was wondering if it would be a good match for the X100? Any thoughts?
I installed a DLE 30 on my X100 and had to remove it after 2 flights because of the reasons stated above plus the insane power of the dle 30 was unmanageable. My 2 cents.
#3653
RE: Funtana X100
#3654
RE: Funtana X100
Hey all had a radio out with my 100x and i have fixed all damages and am in the process of recovering and all that comes with these problems but i need to find out the measurement for the engine mounts!! anyone got a diagram of it or something?
#3655
My Feedback: (13)
NJ
RE: Funtana X100
Just received a well used X100. Will need some repairs and reworking, but the frame itself is solid. Needs to be recovered. The stab supports need to be redone. Ownt know how to do this until I get under the covering to see whats there. Any suggestions?
Does anyone have a new X100 cowl that you might want to sell? Would anyone know if the cowl for the Funtana 125 would fit on the X100?
#3657
My Feedback: (13)
NJ
RE: Funtana X100
ORIGINAL: 674nathan
Cowl will fit so will the f90 cowl. I dont suppose you could tell me the engine mount position?
#3658
RE: Funtana X100
I mean the actual position on the firewall as i had to replace the engine box. So i need the position of where the mounts ore attached to the firewall, thanks.
#3659
My Feedback: (13)
NJ
RE: Funtana X100
ORIGINAL: 674nathan
#3660
My Feedback: (13)
NJ
RE: Funtana X100
ORIGINAL: 674nathan
#3662
WA
RE: Funtana X100
I built my X100 about 5 years ago. It was hanging in my garage until 3 days ago. I can't believe i waited soooo long to fly this thing. Just awesome. CG is at 6 3/8" and it lands better than a trainer.
#3663
RE: Funtana X100
can anyone help source replacement landing gear for the x100?
I know the funtana 125 landing gear will fit, but H9 doesn't have stock till mid november.
Anyone know which gear from HobbyKing will work?
Thanks!
Thanks!
#3664
My Feedback: (19)
NY
RE: Funtana X100
I don't know about Hobby King but I used the GraphTech landing gear and it has functioned
perfectly.
http://www.graphtechrcshop.com/produ...3&categoryId=6
This may be an updated version than the one I have but I am sure it will fulfill
your needs.
krop
perfectly.
your needs.
krop
#3665
RE: Funtana X100
checked out the site earlier and they have it listed as back-ordered right now. I sent them an email to see how long till more stock is brought in/created.
#3666
RE: Funtana X100
NOREPLY...JUST DATA
I have a Futana X100 that I bought used as a fix-it plane. I am getting it back in shape. I have no manual and would like to get the CG point and where it is measured from. Also I have noticed a lot of broken Funtana,s that seem to have broke in about the same area. I am using lite-ply (1/8 inch)in my last brace area. It will have a piece of 1/4 ply along the landing gear block too. Below is a couple of phots of the template to get the lite ply piece made. Capt,n
#3667
RE: Funtana X100
right from the manual: (you can download it from H9's website)
The recommended Center of Gravity (CG) location for the FuntanaX 100 is 6
3/8"–6 3/4" (162mm–171mm) behind the leading edge of the wing against the fuselage.Note
: The CG can also be measured at the wing tip. This measurement is 3 1/8"–3 1/2" (79mm–89mm) behind the leading edge of the wing.
#3668
RE: Funtana X100
Akito1, For ony having done 5 postings...you sure did a good job of replying with good data. Take care...and it is good to see you with RCU. I hang out in the Gas engine, engine conversions and the ARF forums. Lot too choose from. Enjoy. Capt,n
#3670
RE: Funtana X100
Well I got the repairs done a couple of days ago on my Funtana X100. This eve I flew it for the first time. It only needed about 1-2 clicks of up trim and it seems to fly nice. I do need to set the dual rates better. May fly it tomorrow if weater permits.Best Regards,Capt,n
#3673
RE: Funtana X100
UPDATE I got the Funtana 100X together and made 2 flights. Seems to fly good as ever. Did not need any trim from previous settings. I hope I can get as many hours flying it as it took fixing the creature!!!!!!!!!!!! Best Regards Capt,n
