Funtana X100
#1226
RE: Funtana X100
ORIGINAL: aviateur2
And I forgot to say that all my electronics stuff was brand new last summer not some stuff from a couples of years ago and in my funtana X100, all servos are brand new (S3010 futaba) They never gone inflight yet
Those servos are 74oz torque on 4.8v and 90oz torque at 6v. 90oz is enough for the fx100 but with oversized controls, your servos only have plastic gears and this is what might-will happen. One tooth on the plastic resin gear is going to break during a rough landing or just from the load, and then youll have flutter that might-will destroy you plane. Dont ask me how I know that! Metal gear. just my 2 cents. Good luck
#1227
VA
RE: Funtana X100
In my X100, I am using a 4.8 volt 2700mAh nickel metal battery and I fly all day. No problems at all. Are you guys with 6 volt batteries using a voltage regulator? Without one, you could fry your servos.
#1228
WV
RE: Funtana X100
Reyn,
I think you have plenty... As long as you load test the battery before each flight with a .5 Amp load and it is still above 4.8Volts go fly...!
I don't have my chart at work but I used a inline Amp/Volt meter from Hanger9 to check my servo install on my Funtana and other Aircraft and found that even loaded the 5645 was only pulling .22 amps... With my boys help, grabbing every control surface we they could hold on to, we only created a load of 1.2 total amps... That means my 1950mah battery could support my plane for an easy 40minutes of flight time..... And that is at max flight load which just doesn't happen even doing 3D...
Just make sure your battery will put out above it's rated voltage under load before flying and you should be good... Ok.. I'm off the soapbox.. LOL
Good Luck,
Hibrass
Good Luck,
Hibrass
#1229
WV
RE: Funtana X100
Oh...
On the JR ST125... I tried 5 on my Funtana when I was first setting it up... I had a lot of weird glitches in mid movement out of 3 of them... One elevator and both Ailerons.. I replace the whole lot with 3305's and it stopped.. I have no idea why it happened but JR was good on the return so I can't ask more than that...
Hibrass
Hibrass
#1230
VA
RE: Funtana X100
ORIGINAL: FLYMIKE
What engine are you running? If you are running a heavier motor you will want a battery that will put you cg on track without adding extra weight.
Im running batts from cheapbatterypacks.com. They make them-up to what you need.
The ones I had built were (5C/IB 1400/flat/22AWG wire/ hitec male) but im using a motor that weighs almost the same as the saito125. And my servos are analog (HS-645mg) yours will drain more power.
If you want to fly all weekend without charging the Fromeco 4500 or 2400 lith-ion are great but you will need a regulator and charger for that too.
#1231
My Feedback: (15)
AE, GERMANY
RE: Funtana X100
Regulators are cheap and easy to use. Install them after your switch but before your RX. I recommend a 20amp rated heat sink version for 3d flying.
Troybuiltmodels.com
fromeco.org
Duralite
There is no guess work at all to regulators. One 2400-2600 pack should be fine in that plane. I run Lions in my planes from 40 size to 40% and I fly everything in between!
Troybuiltmodels.com
fromeco.org
Duralite
#1232
RE: Funtana X100
ORIGINAL: skorman
You bring up a good piont. Call your radio manufacture if you havnt used a 5c before to see if your reciever will support it. Some will only support 4.8 and I probably wouldnt hook-up just one servo to the rx with batt. and play around for awile.
Some servos only support 4.8v too.
#1233
QC, CANADA
RE: Funtana X100
Ok I wrote to hobbico tech support about my problem and here is what they say:
If you are using high current draw servos(high torque or digital),what you may be seeing is that the battery voltage drops which is indicated on the Voltwatch.
Depending on the batteries capabilities to discharge the current needed,from time to time,as the battery's current level starts to fall off,it starts to draw off of the voltage.
The Voltwatch sees this voltage drop and indicates this via the LEDs.
Although it is momentary,when to much of a load is placed on the battery the voltage will decrease.
As the load is taken off,the battery voltage comes back up.
The primary thing is to make sure that your battery can handle the demands of the servos being used.
So If I have understand right, the flymike and tsyssa deduction was right about too little battery pack and I remember that guys at local field was working with pack bigger say 2700 mah. I will upgrade my flypack to see if some diffence will be on. tahnk you for your help. it's a good thing to be able to write on this tread.
#1234
RE: Funtana X100
#1235
QC, CANADA
RE: Funtana X100
Sorry It's my mistake. Sure you were right too. I will try some packs with more mah and I will try to know if I can go with 5 cells pack. thanks to all of you.
#1237
RE: Funtana X100
Quick question.... where does everybody have their CG? Well, not everybody... I'm not a 3D flyer, I guess you'd say I'm a sport flyer. I have the CG set on the forward end of the H9 recommended range (don't remember exactly what it is), and the plane is still very "neutural".. just the slightest elevator movement causes a dramatic change. I don't want to set it so far forward that is unmanagable, but I've already moved the battery/receiver bar about 1 inch forward of where it originally sat. My receiver and batteries are fairly light, so that's not making a tremendous difference. Frankly, I thought with a 120 sized engine, I'd expect to put weight on the tail for balance, but I've actually wound up moving everything as far forward as possible and its still too responsive for my (unskilled) taste.
I love to fly it, but those first few stick movements scare the s&*t out of me!!
#1238
RE: Funtana X100
i have my cg exactly in the middle of what's printed on the manual. im running a thunder tiger 2 stroke which is just the perfect weight for it.
i'll i did was put the 6v 2700 5c cell battery behind the throttle servo on a piece of hard wood i found in the shed. mine's fine. i also have standard high torque's in the tail. nothing special. i can tell you that my plane balances in the neutral position. its not tail heavy nor does it nose down when balanced. it stays level.
#1239
RE: Funtana X100
Oh, mine seems to be balanced fine, will fly slow and level with no stick input, flies inverted with slight pressure. But, even on low rates (which are 30% right now), a little elevator goes a long way. I guess I'll get used to it eventually.
#1241
RE: Funtana X100
I took the plane out again this weekend... winds were gusting over 20MPH, but I had to get some stick time...
I had moved the CG forward, moving the battery and receiver almost 2 inches forward of thier standard location.... On low rates, it flew like a trainer.. very stable, predictable, no sharp movements from control input. I also dialed the middle and high rates down a bit and increased the expo.. now the travel is at 15% on low, 35% for medium and 60% for high rates, with 30, 50 and 70% expo.
Middle and high rates were much better after the adjustments. I gave the sticks to one of my buddies that does fly 3D. He flew a few rounds to get familiar with the plane, then popped into a hover.. said there was almost no rudder correction needed, even with the wind gusting like it was... the plane was standing still on its tail, but blowing away from us rapidly.
Its amazing how much difference the balance can make, even on a plane this light and long.
#1243
RE: Funtana X100
I haven't measured how far back it is from the LE... I was just moving weight forward to see if it got more comfortable... I'll put it on the stand tonight and get a better idea.
I guess I should clarify my earlier statement... I didn't move the CG 2 inches forward... I moved the weight (battery/receiver) 2 inches forward... it may have moved the CG a half inch or so. Sometimes my fingers get typing before my brain gets in gear!
#1245
VA
RE: Funtana X100
ORIGINAL: Jimeni
Anyone have tips and pics for sealing the aileron hinge gaps?
#1246
QC, CANADA
RE: Funtana X100
Hi Jimeni! to answer to your question, I did them on both my X50 and my X100. first on my X50 I did the bottom with clear monokote and the side up with the smae color as the wing is (white) What i did is to cut a pieces of film of 1ΒΌ" on the cross side of the roll, with that piece I fold it in two on the long side so I got a pieces of 24" X 5/8". I fold it the way the finish side was inside the folded pieces. Peel the back off and place it in the aileron hinges lines and fix it as usual. After that I only trim the excess with a brand new blade to make a good finish. on the X100, I did it with the same color of the joint (so yellow on bottom and white on top that's it.Hope it will help !!!!
#1248
ME
RE: Funtana X100
Just curious, since this is a gap seal which I am assuming is to keep any air flow from being allowed to pass through why is it necessary to do both the top and the bottom. Wouldn't just sealing one side serve the purpose or am I missing something?
Charlie
Charlie
#1249
QC, CANADA
RE: Funtana X100
Here is some photo of mine. And for the pic of the eagle with flame tail, I did a printout of the picture the size that fit the whelepants with word cut it along and glue it to pants with gluestick like PRITT and cover it with scotchtape 3" wide that I cut little larger than the design. I don't know what it will gives after several flight but I try it anyway.
#1250
QC, CANADA
RE: Funtana X100
Well foxfoto, you don't have to do both side, It's just my preference that's all.In my mind, the air passing trought the hinge line couldn't peel of the seal as both side are gaps But of course you can do only one side
