Free DVD of the Tucson Aerobatic Shootout is ready for download
NJ
RE: Free DVD of the Tucson Aerobatic Shootout is complete
That will be great as another option for people to download the iso.
Marc and I have been trying to get this to work but this is my first time playing around with torrent and I'm not sure if I have everything set up correctly for the client running on my machine. So this will give something to test with.
ORIGINAL: Sired by Fire
i ll make a iso torrent and host it on demonoid tonight
FL
RE: Free DVD of the Tucson Aerobatic Shootout is ready for download
Guys,
I would highly suggest using some form of download manager to get a file of this size via HTTP. There are many available -- some free. I prefer ReGet myself. You can even use one in 30 day demo just to get this file. Using a manager will allow you to work around any browser issues and allow resuming if needed.
Examples:
1. ReGet
2. GetRight
Do a search on Google for many available ones.
Regards,
Wayne
Examples:
1. ReGet
2. GetRight
Regards,
Wayne
UT
I got the file "downloaded" , but then when I went to combine it into an iso image, it said the files were corrupt. When I look at each of the files, the file sizes are all wrong. There must have been a problem in the download. Has any one been able to download and combine the 4 files succesfully? I hope I can get it to work, and thanks for putting this together.
LT-40
LT-40
#32
My Feedback: (46)
My "part 4" file does not match in size, it's 797 Mb and I'm also getting the same error, file corrupt it said unexpected file end or something like that, so I'm guessing it's not downloading all of the 4th one. My first 3 match the size you have posted in the directions.
#33
Just delete the file that was incomplete and redownload. I had it happen on mine too for some reason and just redownloaded. LMK if this works
#34
My Feedback: (46)
Yep worked, I downloaded it again this morning and it worked.
I used my own burner software, and it worked great.
Nice job on the video, thanks for all the effort that went into it.
I'm burning some extras now to give out at the field.
#35
ORIGINAL: camss69
To anyone else who had any kind of corrupted download just redownload again until they come in correctly and then combine. It may be that the files are so big so if it glitches anywhere along the way it could break in certain circumstances. The fix is to just redownload any of the segments that did not come in complete. the first 3 files are the same exact size.
check www.rcuvideos.com/dvd for download and burn info
marc
#36
NJ
I would also suggest trying a download manager like ones Wayne(sl1200mk2) had mentioned. I also found one on Download.com that is completely free to use.
http://www.download.com/Free-Downloa...ml?tag=lst-6-5[link]http://www.download.com/Free-Download-Manager/3000-2071_4-10578059.html?tag=lst-6-5[/link]
If you seem to be having problems you could give one of these a try. These downloaders are great because if your download is interupted it will pick up were it left off. This can be a great time save plus you can queue up a bunch of downloads for it to manage.
#37
ME
Weird, I burned to disc and can see the video (no sound though) in Media Player, but it won't play on my DVD player attached to my TV. I put the disc in, it trys reading it then says "No Play". Any ideas? And by the way, thanks for providing this
#38
ORIGINAL: jzinckgra
Also you might try to ensure your iso image is intact by running the hashcalc on it to ensure it downloaded 100% intact and combined ok. info on that is at http://www.rcuvideos.com/dvd
#39
ME
I ran the hashcalc and all was fine. My DVD player is about 4-5 years old, so maybe that is the problem. Should I be able to hear the sound on Media Player though or are the audio files not recognized by that program?
Also, I burned to DVD+R
#40
ORIGINAL: jzinckgra
marc
#41
ME
marc, thanks for the response. I actually burned using nero express and chose the "make data DVD" option. That may be why I am not hearing sound, but when I tried using the "make video cd" option I get an error and it won't burn.
#42
Help !
i downloaded the one ISO file, is that the whole thing, or do i still need to get the 4 incremental files too
thanks
tom
thanks
tom
#43
ORIGINAL: TomG3D
Help !
thanks
tom
Help !
thanks
tom
you can either grab that ISO in one large chunk 4GB or grab the 4 segments and piece them together on your computer using the first chunk which contains the auto combiner (the .exe file) which will make up the one large 4GB.
you are good to go and burn with the one ISO!
#45
My Feedback: (21)
NY
I got it to work. However on my computer you have to manually load the .VOB files which takes a couple clicks.
Just hit the menu button or on some programs, load playlists. Then it will ask you to browse for the DVD on your computer. Choose the DVD drive. Then you'll see the VOB's in the list. Then select them all with shift click or use your mouse. Then click ADD then click on ok to load the playlist. Then just hit play on your player and the menu will pop up. Or just keep clicking on next chapter to view the segment you want to watch. Each chapter is titled ... real nice.
Thanks Marc, good stuff. Keep the coming!
#46
ME
Bummer, my DVD player does not read DVD+R. So I either need to buy another DVD player or burn to DVD-R media. I'd rather not watch an hours worth of video on my computer, plus I'm still gettting sound.[:@]
#47
ORIGINAL: jzinckgra
Can't get CDBurner Express to work either. It is telling me that it only supports files up to 4.2G.
try the CD Burner XP Pro I noted in the tutorial on www.rcuvideos.com/dvd and write the iso to disc and it will work if you cannot figure out how to get CDBurner Express to write the ISO. A DVD+R should work fine
#48
NJ
One thing to try to see if the ISO download is ok and that there isn't a problem with playing DVD's on your PC's drive. I use a program called magicDisc which is a free download and it allows you to mount disc image files like an ISO.
http://www.magiciso.com/tutorials/mi...c-overview.htm
[link]http://www.magiciso.com/tutorials/miso-magicdisc-overview.htm[/link]
After you download this program and install it you can mount the ISO which will make it look like another CD/DVD drive on your machine. Now you can try using either media player or another DVD player software to watch the video.
I know I have a problem with the DVD drive on my machine to when trying to play a DVD. After burning a DVD from the ISO I tried to watch it with Nero's Showtime and it had some problems but when I mounted the ISO and used Showtime this time it played it fine.
The problem with the DVD player could be because of it age and doesn't support DVD +R. If you have the manual or find it on the internet it make tell which formats it supports. You also might want to try eject the DVD and trying it again. I've had this happen on my newer player and opening and closing the tray seems to get it to work. I actual had this happen to day when I was watching one of my SKS videos. I had watched part of it this morning and had stopped the play back and shut down the DVD player. When I went to continue watching it the DVD player said no disc inserted. I did the tray thing and it found the disk and started playing it.
#49
#50
ME
ORIGINAL: RCadmin
sounds like you are not writing the ISO image that is why it tosses the error.
ORIGINAL: jzinckgra
