Reload this Page >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 07-13-2005, 01:58 PM
  #2801
Barry Cazier
My Feedback: (17)
Default RE: U-Can-Do 3d 46?
raideron. Dang. Glad the damage was no worse.
Two questions.
1. Prop?
2. Do you want to buy a timer?
Also, my personal experience has been you propably won't use more fuel with the 91 in there. You will probably use less full throttle and thus will be operating the engine in the mid to low range and you will have better economy there. Most times I've gotten better milage with the bigger engines. One way you can tell is fly for a minute longer and if you deadstick at about the same time and tear the gear out again, it's getting about the same milage.
Barry
Old 07-13-2005, 03:39 PM
  #2802
raideron
raideron's Avatar
Prop is a 13X4 Pro Zinger... As you can see it has had a pebble nick...
Can you sew it???
Timer...... I think I had less damage without a timer verses??:-) No, let
me condition my mind:-)... Which includes not letting the peanut gallery
to entice my flying:-)
With the YS, I do very little full throttle flying.. except for uplines and
hovers(now in this thin air).. Most is at 1/2-3/4... But the YS does run
dripping rich... So it maybe close to the same....
I like your test.... You know I will most likely test it that way:-0
You have a Great one.... My S.T. is on it's way:-)
Old 07-13-2005, 06:13 PM
  #2803
gjeffers
gjeffers's Avatar
never a dull moment here, you guys are great one thing about a crash is its built better when rebuilt or you get to see that blessed brown truck and we all know how much fun that is,wait that is two things, oh well, cant wait till the weekend. keep er up Ron[8D]
the best thing is Barry is sounding like his old self again
Old 07-13-2005, 06:24 PM
  #2804
cafusin
Hello,
I fly in Mexico City at an altitude of 8000 feet above sea level so we lose about 25% of power compared with sea level fliers. I´ve just bought a U Can Do .46 and I am not sure which engine to install. I have a Supertigre .75 2 stroke a .82 Saito 4 stroke and a OS .91 2 stroke. I´m not sure I want to install the 2 strokes due the inverted position of the engine. Since all of you have flied this plane and many people overpower it, any suggestions?
Eugenio
Old 07-13-2005, 06:32 PM
  #2805
raideron
raideron's Avatar
I tell you Gary... It's Great... A bit "HOT" My carport threm.
is showing 119... The one closer to the sun is at 125.....
No break on the AC... :-( Which means.. No work on the UCD
Old 07-13-2005, 06:40 PM
  #2806
gjeffers
gjeffers's Avatar
cafusin, i have a saito 100 in mine and its just about right in the heat here(80deg in morning and 110 in day) and im at 1700 ft, it is over powered in the cooler parts of the year but i like it and fly accordingly, have over 120 flights on it and no structural problems. if i were you i wouldnt go less than the 82.
Ron, it is a little hotter there as its only 112 here and im not flying in it, no i wont, i wont go, will wait till sat morn where it is cast to be 82 at sunrise, just right and sunday too!!
Old 07-13-2005, 07:03 PM
  #2807
Barry Cazier
My Feedback: (17)
cafusin, I would follow gjeffers advice and stick the biggest engine you can in that thing. Even if you have to add on to the front. You are gonna need it. And you should run high nitro. I always tell people when they ask me "why do you always use 30% nitro?" I say, "because I can't get 40%."
The other thing you can do, although a bit more difficult, is lower your elevation.
Hey, what's going on??!?!?!? It's 101 degrees in Idaho Falls, Idaho?!?!?!?! I can't believe it. Hurricanes in Florida and hot weather in Idaho. Somethings brewing...
Barry
Old 07-13-2005, 08:32 PM
  #2808
EL TEMUCANO
EL TEMUCANO's Avatar
i always tell , i have an OS 46 ax on my ucd,, and all of you tell me put more power. No body said thats the correct engine.............. on flying circus some body tell me if i want fly like a foami, buy it, but .46 is´n the engine.
well thees week i change my engine and i put a super tigre g 90 with APC 14/6, i don´t fly yet but if thes weekend dont rain , i have a new experience with my UCD.
Sergio
Old 07-13-2005, 08:53 PM
  #2809
former spad
I have a Webra 50 2 cycle. Nearly 60 power, with nearly 46 weight. Hi compression engine that does not need high nitro.
Old 07-13-2005, 09:02 PM
  #2810
gjeffers
gjeffers's Avatar
Sergio, you are gonna have a Ballyour gonna be spoiled now and love big power, you come back and tell me im rightor wrong[]
Old 07-13-2005, 09:28 PM
  #2811
EL TEMUCANO
Gary,
i think thees will be better, but i´m "worried" becouse the fuselage it´s so breakable.
a have to land so carefully.
i´m waiting saturday
Old 07-13-2005, 09:41 PM
  #2812
gjeffers
gjeffers's Avatar
Sergio, only the landing gear block proves to be weak, if you have already strengthend it the rest of the fuse and firewall should be ok, mine has held up real good, so no worry, have fun, and if the worst happens just blame your fingers
Old 07-14-2005, 02:35 PM
  #2813
rtn9105
My Feedback: (35)
Has anyone had a problem getting their UCD to knife edge? My rudder won't hold the plane in knife edge, even with full rudder throw and full throttle, the plane still decends in knife edge. I have a 90oz servo on my rudder so I think it should have enough holding power.
Old 07-14-2005, 04:56 PM
  #2814
raideron
raideron's Avatar
rtn9105, Not sure what engine your using or if your CG is OK, But I have
no problem holding a K.E.... I have a YS 63 and my CG is close to 6", But
you do have to work the stick due to the coupling that this plane or maybe
just my plane has, that's on both elev. and ail...
Old 07-14-2005, 05:04 PM
  #2815
Barry Cazier
My Feedback: (17)
Mine will gain altitude in KE. I run the 82. Mine does a nice KE coupling as well. If you want to stop the coupling you gotta "fly" it. But I have plenty of rudder to KE loop. My guess, you're a little under powered or you're not getting full throws for some reason on the rudder. She'll do them.
Barry
Old 07-14-2005, 06:03 PM
  #2816
gjeffers
gjeffers's Avatar
mine will knife straight up(when the wind blows hard enough)[X(]
Old 07-14-2005, 06:31 PM
  #2817
TSuppa
Well after much debate I purchased a Saito 100 for my new U-can-do. I just finished doing the break-in procedure. What a sweet engine. Can't wait to fly it. How do you prep the plane for re-entry into the atmosphere???
Old 07-14-2005, 06:48 PM
  #2818
Barry Cazier
My Feedback: (17)
You'll love it. One of the neatest planes out there.
Barry
  #2819
TSuppa
gjeffers,
what are you using for a prop?
Old 07-14-2005, 06:49 PM
  #2820
Barry Cazier
My Feedback: (17)
Swen are best.
Barry
Old 07-14-2005, 07:12 PM
  #2821
EL TEMUCANO
HELP......
WHEN YOU USED A HIGHT POWER ENGINE,,,,, YOU PUT WEIGHT ON THE TAIL??????????
I TRY TO PUT AT 6" THE CG BUT[][]
SERGIO
Old 07-14-2005, 07:18 PM
  #2822
sctcrash
sctcrash's Avatar
I still havent gotten my knife edge down yet, but is is no fault to the plane. I think if I didnt have clumbsy thumbs I could do a KE loop. My biggest problem is the coupling, atleast what i think you are all referring to as coupling. When I am in knife edge the more rudder I give the more Aileron and Elevetor I have to give. I still have not been able to work Rudder, Aileron and Elevator all at once. Are there any good radio mixing tricks to help with these tendencies without hurting other tricks.
Old 07-14-2005, 07:21 PM
  #2823
raideron
raideron's Avatar
SERGIO..... Before adding weight, Mount the engine as far back as possible
on the mount... Move onboard equipment towards the back as far as it will
go... If you have a mini servo(throttle), that would help, The battery can be
placed as far back as it is needed with some simple mods to help with getting
the CG as you want with the use of an extension for the connection... But some
times you "may" still need some weight, But that should be the last resort....
Old 07-14-2005, 07:26 PM
  #2824
raideron
raideron's Avatar
sctcrash.. Not sure what radio you have, But most computer radios have
a rudder to elev. and or ail. mix...( both elev./ail.(slaves) moves when
you use the rudder(master), by what ever % you set on the radio) which
is switch activated.. So it's on/off when you want it. If you have a comp.
radio check your manual...
Old 07-14-2005, 07:31 PM
  #2825
EL TEMUCANO
YES, I´M USING MINI SERVO FOR THE THROTTEL AND THE BATERIES ARE UNDER THE NUT OF THE WING, FOR ENGINE THE INSTRUCTIONS SAID 5" (BACK PLATE OF THE SPINER FROM THE FIREWALL) I PUT AT 4 1/2" , DO ANYONE KNOW ANOTHER TIP FOR MOVE REAR THE CG????? I NEED MOVE 1"
SERGIO
