 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 07-20-2003, 08:33 PM
  #276
BUCKETOBOLTS's Avatar
Default RE: U-Can-Do 3d 46?
I have my Can-Do ready to test. Haven't weighed in yet but using a Saito 100 and BB standard servos on 5 cells. Balances around 5" with the battery under the tank.
Test run the engine a while ago and one word will describe the 100 on this air frame...MEAN!!!
Old 07-20-2003, 08:35 PM
  #277
I didnt find the damage untill i pulled the covering off. Just picked it up at the LHS yesterday, If the UCD was offered as a kit or ARC i would have bought that, but for the price its still worth buying and re-covering to my liking, i wasnt going for the Mcdonalds color theme, i could also shave some weight by using lighter/transparent covering and getting rid of most of the 2 and 3 layers of monokote that it had on it. This is my first ARF and i just cant leave it well enough alone......
Dylan
Old 07-20-2003, 08:42 PM
  #278
My Feedback: (22)
figueroa's Avatar
Nothing wrong with perfection !
I would like to see the new and improved UCD when you are done. I'm sure it will look great...
Regards
jef
Old 07-20-2003, 10:47 PM
  #279
I installed an OS 70 Surpass II with a 13X4W prop. The plane will hover but with the existing engine it lacks authority. The vertical climb could be much better. So, I've decided to get a Saito 100 based upon the posts I've read here at RCU.
For those of you who fly the plane with the Saito 100 what prop are you using?
Regards,
Scooterpilot
Old 07-20-2003, 10:52 PM
  #280
Regards,
Scooterpilot
Might want to try a 14x6 or 14x4W before ruling the 70 out
Dylan
Old 07-21-2003, 02:12 AM
  #281
My Feedback: (8)
rcflyguy_26's Avatar
I had the first flight on mine today... Total wing failure!!!!
I'm going to look into it more tomorrow. I think the servo mounts on the right wing let go. All four screws were in the servo, but the closest rib was shattered. the wing half landed on top of the beans, so no damage from ground impact. The wing separated at this location.
I was coming out of a left hand turn, level, when it came apart. I was at half power.
The saddest part is the innocent dead ant that I found on the saito 91. He didn't know what hit him!
Has anyone else had this happen?
Thanks, Scott
Old 07-21-2003, 02:27 AM
  #282
I gotta tell ya, I was thinking about getting one of these but after reading the post here i will pass.
Thanks rcu.
Saved me once again.
Old 07-21-2003, 06:48 AM
  #283
My Feedback: (45)
well i flew mine today like 12 times and so far with the os engine in the front it does great no problems what so ever (knock on wood)
Old 07-21-2003, 10:36 AM
  #284
My Feedback: (21)
Thanks rcu.
I could not be happier with my UCANDO. I have not flown my 60 since I got it. No reason to. The 46 is much better as a flyer. It is not a heavy duty as big bro, but more fun for sure.
Old 07-21-2003, 02:22 PM
  #285
ya i dont understand why this thread would make you not buy one. every plane has questionable aspects, and possible improvements, and the ones for the ucd are quite mild compared to most. Any plane you get a review of will have some negative feedack from someone. what mostly turned you away from this plane? compared to others?
Old 07-21-2003, 05:05 PM
  #286
Well, every review i read about the GP Venus said nothing but good and i gotta tell ya, i got one and there is no bad on this plane. Other than it does not 3D.
What turned me off?
Heavy, Why else would you put a Satio 100 in a .40 size plane.
Wont balance with rec eng, purpose for said eng or dead wieght.
Fragile, Most get theres and the wing is broke or they are afraid of picking it up in fear of breaking somthing.
Coupling in K.E.
Hard to harrier and flat spin.
Hovers easy but theres a whole lot more to 3D than hovering.
If the plane was not fragile and came in at the wieght the box say's ( so i can use my 46fx ) then i would have one but, after reading this thread i dont think that is possible.
Old 07-21-2003, 05:28 PM
  #287
My Feedback: (21)
Coupling in K.E.
Heavy? Hardly. I am running a Magnum 80 that is hard to keep it from climbing in hover <1/2 throttle. Saito 100 is overkill. I have no weight on the plane anywhere. Lil tail heavy just like I like it. Totatlly stable.
Fragile? Yes. What good 3D plane is not fragile. I would not expect it any other way. I have flown my 46 UCAN more then 25 times now, still like new. You just have to re-enforce the landing gear as with 90% of all RC planes. Since the plane lands with less then 5-10 feet of ground roll, i believe it could even be built lighter.
Hard to harrier? Nah ... hit the spoilerons ... instant harrier.
As far as 3D. Graceful, nimble, forgiving and responsive. Forgiving is deadstick in hover between 10 and 15' and still recover no prob.
Coupling in knife edge, yip, skill and practice overcome that.
Get it, try it. Don't like it, someone at your field will pay you what you paid for it built without a loss.
Old 07-21-2003, 05:31 PM
  #288
My Feedback: (20)
To STLPilot-
I have the same setup with the Magnum 80 4 stroke. Can you tell me what props you have had luck with?
Old 07-21-2003, 07:10 PM
  #289
What turned me off?
Coupling in K.E.
i agree with most your post, however keep in mind a stable pattern plane is not as difficult to make as a 3d airplane. Too me all the ucd is a narrow body pattern plane with a more stable wing and bigger control surfaces for the 3d. as for it being underdesigned. i dont really think it is. i dont know if you have seen this plane in person, but it is large, out sizing the funtana and is about the size of most 60 size planes. I suppose thats why they called it a .46 isntead of 40 size. However if you are looking for a fun fly type plane, id recomend this one, because you get some nice pattern type characteristics along with some good 3d characteristics, and it actually resembles a plane somewhat, well alot more then the comparably priced funfly 3d planes out there. Anyways im not pushing you into this plane or anything, just sticking up for it, and reminding you that it takes allot more to desig a 3d capable plane then it does a pattern.
Old 07-21-2003, 08:48 PM
  #290
Thanks for the repelys. Most of it made scents's.
No i wasnt looking for a fun fly type plane. I was looking for a 3D plane. One that i could use my 46 fx in and beable to take the wing off. I had a OMP 540 profile and loved it dearly! Did everythinng i could and then some. The only prob i had was it was one piece.
Old 07-24-2003, 01:07 PM
  #291
hey guys i'm gonna give it a go witht the tower hobbies .75................now i will not have a flight report till next year i plan to get the UCD over the winter.............for my only 3D plane i really will only use it to bore holes in the sky and do cool stuff that i dont get to do with my pattern planes
Old 07-24-2003, 04:23 PM
  #292
My Feedback: (21)
UCANDO will not flat spin right side up ... but inverted will flat spin with the best of em!
Old 07-25-2003, 03:02 AM
  #293
Anyone get it to flat spin right side up? I've tried a couple of times and ended up spinning inverted even when i was trying right side up!
Old 07-25-2003, 11:48 AM
  #294
My Feedback: (21)
ive done plenty of simulated upright flat spins. they look like about 75% of the real thing
Old 07-26-2003, 12:07 PM
  #295
I just picked up my Saito 100 yesterday. All that's left is install engine and radio gear, hopefully it will be the air early next week. To much going on and not enough time. Also going to go with a 16 X 4W APC prop, should be just right with this engne. I also picked up a 1500 mah NiMH 6.0 volt battery pack. I wanted the extra power and speed the 6 volt gives. I will be using Futaba 9202 servos all around except on the rudder where I am going to try a Futaba 9253 digital servo. I have an extra one from my helicopter and want to see how it works.
Old 07-26-2003, 01:22 PM
  #296
I received my saito 100 last week. Friday night I broke the motor in and I've installed a 16X4W prop on it. The motor idles great and transitions to full power great. This morning well see how it flies.
Regards,
Scooterpilot
Old 07-26-2003, 01:44 PM
  #297
[i] I will be using Futaba 9202 servos all around except on the rudder where I am going to try a Futaba 9253 digital servo. I have an extra one from my helicopter and want to see how it works. [/B]
That 9253 is a great heli rudder servo. At 30 oz of torque it pushes low resistant surfaces around at a blazing speed of .08 of a second. Unfortunately you need about 90 oz for the rudder on you UCD 46. Try the 9350 @ about 130 oz and .12 or so.
Leo
Old 07-26-2003, 07:45 PM
  #298
I test flew my Can-Do this morning. WOW!!! the 100 rocks it will hover at 1/4 throttle. I need to get a lower pitch prop. All I had was a 15x6apc and at a very low idle she didn't want to land. I'll have to pick up a 16x4 next week.
Old 07-26-2003, 09:08 PM
  #299
My Feedback: (72)
I got my .46 size U Can Do today and after reading the above posts, can't make up my mind to keep it or sell it. What do you think? I have a Saito .80 I was going to hang on it, but the instructions stress not to put more than a .70 on it.
Old 07-27-2003, 12:05 AM
  #300
My Feedback: (31)
bump the instructions put what you want on it and controll the throttle
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
