 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 11-20-2005, 06:43 PM
  #3726
gjeffers's Avatar
Default RE: U-Can-Do 3d 46?
towers, when it goes lateral, does it always go left? if so you might try putting a couple of washers under the mount on the right side(as yur looking at it) between the mount and firewall, this will give you about 1.5 degree right thrust and will help it "hang there"
your servos are ok and i dont know much about your engine but i think the 13x4w would work well on a .61 2stroke
oh------ and to hover takes a lot of practice, a lot (to hover well that is)
Old 11-20-2005, 06:55 PM
  #3727
Towers
the servos are fine
but out a lot of throw on the surfaces
and gjeffers is right
the same thing happend to my but i put in 1 degree right thrust and that isn't quite enough
i'm going to put in another .5-1 degree more in during the winter (the non flying seasion-lol-as i call it) seasion
but my dad and i and other guys at our field fly all year long
30
Old 11-20-2005, 08:13 PM
  #3728
Towers's Avatar
Thanks guys!!!
I need to look to which side does it goes, I'm not sure about that... throws are high but I would give them a bit more
And do you think Nitro gasoline would help its vertical performance?? I use 80% Methanol and 20%lubricant...normal...
Finally what CG do you guys recommend???
Thanx again!
Old 11-20-2005, 09:39 PM
  #3729
Does anyone fly both a Can Do 36 and a Twist? I can't find ANYTHING as fun to fly as the Twist--with an 82 Saito driving it. I have a Can Do 60 with a Saito 1.0, but it's a dog, no fun to fly. Big is not always beautiful. And it's not NEARLY as aerobatic or as responsive as the Twist.
I have considered getting a Can Do 36. That's why I've been reading this forum. But I can save the money and just get another Twist, too. I need to save the Twist and find another challenge. Is it the Can Do 36?
Let me know. Thanks.
Jack
P.S. Other planes in my hangar: P-51D w/ retracts; Model Tech Extra (O.S. .50) and Magic (.45 Super Tigre); Big Stik O.S .60.; Sturdy Birdy II with a 51 Super Tigre.
Old 11-20-2005, 10:53 PM
  #3730
gjeffers's Avatar
Towers, yes on the nitro, 15% at least and i bet that your plane is falling to the left and your having to give right rudder to hold it in position so you will need right thrust
38, you and your dad ever need a vacation from the cold and come to the desert southwest come on down to the mojave desert and well go flying, i have a lot of room out here,(no freeways or traffic lights where i live)
later
Old 11-21-2005, 04:49 AM
  #3731
GJEFFERS - Thanks for the info on the pushrods. I really like the way you did that. Thanks!!!
TOWERS - The other guys covered about everything I was going to suggest. Their advice is right on the money.
As far as GC goes, put it about where the information that came with your plane recommends, and then move it (Usually back), from there. If you get it too far back, you will kinda get a "Mushy" feeling on the elevator. When inverted, you should only have to put a little down pressure on the elevator stick. At least thats been my experience. Maybe one of the other guys can put that into better words than I can. Also, remember to always check your trim, after making a CG change. You will usually need a click or two.
Changing to a 13X4 or 14X4 is going to really make your plane more "U-Can-Do" like. Low and slow is the thing with these planes, they dont like to go fast.
Have fun,,,,,
Old 11-21-2005, 11:39 AM
  #3732
rclement's Avatar
[quote]ORIGINAL: Jack211
Jack, I have flown a friends UCD 60 with a ummm.... I think it was an OS 90 or something like that. Anyway, it was too underpowered for me. Also I had a Twist. Very fun plane but I just couldn't get the hang of it. Since you have one Twist I would go with the UCD 46. Put an 82 or bigger in it and you'll have a blast with it. [8D]
Old 11-21-2005, 05:02 PM
  #3733
I'm putting together a new 46 U CAN DO, Trying to decide which engine to use. Maybe a YS 63 or a Saito 100.
What do you guys think?
Jerry
Old 11-21-2005, 06:39 PM
  #3734
Jack211 ,
i have both and my twist flys like crap[: '(]
i think the ucd flys a lot better
but if you have one that flys better good job
the 46 ucd would be a good plane
38
Old 11-21-2005, 06:42 PM
  #3735
jerry
put the 100 on it
you'll like flying it better
Old 11-21-2005, 08:39 PM
  #3736
gjeffers's Avatar
ditto on the 100, it really is a great engine for this plane and weightwise it balances good too!
ID:	358371   Click image for larger version
Old 11-21-2005, 11:01 PM
  #3737
Okay, setting up my radio. I have a 7CAP. I am now messing with the elevators.
I have a S3151 on each side. I went through the PMix to set up a mix for this. Just
to find out when you use the trim it only trims the master not the slave.
Plus the PMIX when set up per futaba it only moves the horn one way. Obviously
this is NOT the way to do it. So, do I need a reversing y harness? If so I can not
find them on tower. Do I need a 9CAPS? I dont really want to put the money out
for another radio. Would rather buy other planes...help guys!
Old 11-21-2005, 11:05 PM
  #3738
gjeffers's Avatar
heres a couple sd(if you dont have this site, keep it, lots of stuff)
http://www.wholesaletrains.com/Searc...it2=++Search++
Old 11-21-2005, 11:11 PM
  #3739
rclement's Avatar
Here's a reverser. [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAFN1&P=ML[/link]
Darn! Gary beat me to it...... And he could probably fly inverted while posting it too......[>:]
Old 11-22-2005, 11:56 AM
  #3740
Kaos's Avatar
I replaced the problematic Super Tigre G.61 2-stroke engine (flamed out on almost every flight - sure got good at dead-sticks!) in my UCD.46 with a new Magnum XL-70 and it runs great. I now have about 8 or 10 flights on the new engine and I'm wondering if I have the best prop for this combination. I'm running a 13 x 6 (the recommended break-in prop). I can hover at about 3/4 throttle. Anyone have any experience with the XL-70 in the .46-size UCD?
Kaos
Old 11-22-2005, 12:41 PM
  #3741
raideron's Avatar
Towers... All great advise above!!... A flight Sim will help alot (well, it helps
most) It helped me in seeing how important it is to catch any deviation from
vertical as fast as possible.. Before it happens is even better:-)... That way
you will use "Really" small control corrections..<<Very important!!..
Having your model closer to you also helps alot... And practice, practice practice!!
Get the longest, widest prop that your engine will turn.. (4 strokers for me)
IMO max throws for hoving is not needed.. For me the key was, early detection
of deviation, very small control movements and my mind..... A good balanced
model.. vert and lat.. the stock rearward suggestion works well...
Jerry C... A YS 63 worked Great for me, But at higher elevation, thin hot air can/
will effect its performance.... But its hard to beat the pressurized system for the
inverted engine... I'm now using the S-100... and I still can't really answer the is it
better question... I can say it pushes a lot of air... Once you get the throttle control
down the "Do" will hover itself with so much more control... I myself noticed very
little difference on the weight between the two engines, The "Do" still floats and lands
great!! For everything else... Well I think my two previous crash repairs has change
the way my "Do" is flying and I'm still working on finding the "new" setup...
Well now that I did not make the final cut on my new past time... Got booted off
the last chance to make the final game table as the 90th person out of 1500:-( Think
I used up all my Karma to make the table, I finally got the necessary points to enter
the game 10 mins before the game started..... So I have more time.....
I have started putting the S. T. together..... On my choices for my other plane... I
wanted something else... But... waiting on the OMP V2 48" to be shipped after
Thanksgiving.... And trying to adjust the old "Do" to find the setup... Have fun Peeps
Old 11-22-2005, 07:47 PM
  #3742
gjeffers's Avatar
fthats right Rob, and i almost ran out of gas waiting on ya(6 min faster)
glad to have ya back ron, now you can get back to more important things, i think?
i need help keeping CEEGEE out of trouble[X(]
here is my new baby!!
ID:	358811   Click image for larger version
ID:	358812   Click image for larger version
ID:	358813   Click image for larger version
Old 11-22-2005, 08:12 PM
  #3743
rclement's Avatar
Looks good Gary! I thought you were going to put a Saito 125 in it. What did you end up with?
Old 11-22-2005, 08:38 PM
  #3744
sdcranford
i have a 9c and their about the same
on the pmix you need to turn on the TRIM mode
and on the % page put one of the %numbers on
the oppsite of what you have it and it should be fine
[(100% 100%)(should be)(-100% 100%) or (100%
-100%)(if their going the same way but the opposite
of the stik movement use the reverse sitting that's what it's their for)]
my friend has a 7c with a 60 ucd and he has no ys on it
38
Old 11-22-2005, 08:40 PM
  #3745
Kaos
i have a magnum 70 on mine an i have a
14x4w apc prop on it and it flys great
38
Old 11-22-2005, 10:39 PM
  #3746
38,
I dont know how it set it up. I had it as 100% and -100% and switched them too,
still didnt work. Even if it did there is not a TRIM mode on the 7c, just the 9c.
Thanks for the help though!
Old 11-22-2005, 11:46 PM
  #3747
gjeffers's Avatar
Rob, im not ffinished with it yet but thats my 100 in it now, but im ordering the 125 for it, but im very impatient and couldnt wait to get it going, sooooooo i bought an extra cowl for it[X(]
so now im putting the 100 back in my 60 ucd so i can fly with my son this holiday and have a lot of fun and turkey
happy thanksgiving everyone and happy holidays
Old 11-23-2005, 12:16 AM
  #3748
rclement's Avatar
Sounds good Gary. Have a good turkey day your self.
It's a toss up for me between the YS110 and the Saito 125. I'll probably go with the Saito though.
Old 11-23-2005, 04:34 PM
  #3749
sdcranford
sorry it didn't work
did you try switching just one number
also you might just have to trim it on the ground after fly it
again sorry i cant be more help
i only seen the menu 5 times on the 7c
and that was only for minior things
Happy Thanksgiving To All And To All Good Flying
38
Old 11-23-2005, 07:37 PM
  #3750
raideron's Avatar
Looks great Gary.... Let us know how it goes!!
Happy Turkey day to all:-)
Took the "Do" out this morning... What a blast with the S100 in there, My 10oz
tk. last longer too:-) Most throttle position 1/4 or less.. I don't believe I will go
back to a smaller engine... S-100 16x4W for me:-)... Still having some problems
with flat spins with this setup.... But it'll get worked out or in:-( Beside the flat
spins I notice no difference in flight/landings with the S-100 on the nose.. except
unreal thrust.. All else seems so much eaiser to maintain with all that air being
pushed... Plus I have all the extra Wing Harmonice now And the wing is still
together... Well cept for the hinge....
Got a first (with the "Do") the tail did a touch down... :-).... But have
some work to do.... my rt. inner aileron hinge is cracked at the hinge line:-(..
I hope this repair does not take as long as my last..... Well Back to the game:-)
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
