U-Can-Do 3d 46?
#1303
AZ
Hey hockeyrules99... Well, No they were glued in place, But while
pulling on the control surface before start-up of the engine I saw
one(1) and a half of the next one split right down the center on
my ailerons on the wing tip side... If I went up with out my checks
who knows what could have happened... It's very simple and fast
to do, And as I said it WILL save you:-).... Plus at the field a fellow
club member maidened a delta type wing and lost one of the rudders
he landed with no problems, If he would have used the tug/pull before
the flight he most likely would have found it... How do I know.. Because
after he landed and on some of the CA hinged that were sticking out
of the vert. stab. of the missing rudder.. I pulled on it and it came right
out.... He said he CA'ed them good.... We just looked at him.. Then he
said well maybe I had a senior moment, and glued one side twice...
Have a Great Day
Another great day at the field!!!! This UCD just floats like a foamy,
Man, it is easy to fly!! I love it.... Now using a 14X4W and P.M. 20/
20 on the YS-63... She purrs like a kitten and my 8oz tanks is
lasting longer, I'm hardly ever above half throttle... And I think the
name is right(UCD).... I think I can do... At least so far of using
about two gals. But you know what they say.. It can get you in
trouble.... I can't wait for the Yak:-))))))))) It's a day or so away
Have a Great Day
#1304
hey guys,was wondering if the tank was as easy on the 46 as it was on the 60 to put over cg? i have a 60 but my son is getting a 46 and was asking questions about this.
#1305
AZ
I'm new to the UCD, But from what I see No way to do it, there's
just no room, unless you blacken the canopy and use that space
too??? and move the onboard gear around... Since I am running
a YS-63 and I had to replace the tank, I was thinking about that,
But I'm too green at this, and wanted to fly, So the tank went
right back where it came from...
#1306
KS
i agreee with raideron about the tank placement. There are some tanks out there that are very pliable when you heat them with a heat gun. I just put the tank in the recomened spot with a magnum 70rfs, put the receiver as far forward and placed the batt in the spot infront of the servo tray. After the first flight I moved the batt up to the receiver and that put the cg right at the 4 1/4 to 4 1/2 mark.
#1307
My Feedback: (17)
ID
Barry
#1308
AZ
With my rude check of the CG, I thought I was at 6"maybe a hair
more from the LE, But not sure now since goldenclan's onboard
set-up sounds to be as mine is in post 1271... I do need a little
down to help her get down, and inverted flight just take lite touches
of the stick every now and then at mid throttle setting and on full
throttle she will climb.. Anyway what the heck.. I like it:-)
#1309
WA
It is a fun plane to fly. If mine crashed I would surely buy another. I'm even thinking about selling my 4*40 since I never fly it. The 4* only has about 8 flights on it. I have an Ultra Stick also and between it and the UCD I don't get the 4* into the air. The UCD is the funnest plane I've ever flown.
#1310
TX
Do yall have any hints or ideas for mixing, elevons, expo, etc. for the U can do? What have some of yall done that has been successful?
FYI, My U can do is the Official Base Drum of the field.
Thanks for the help,
Daniel
Daniel
#1311
KS
The ucando has to be one of the most forgiving plane I have flown. I had a trainer that had stall habbits worse than the ucando! So far all of the landing roll outs have been less than 5 to 7 feet with one that just stopped and set down on the ground! As for mixing, I have used the flaperons and set up just to give a bit of flaps and it will crawl in flight and just hang around in some wind. I have not tried any eleverons or the such or any coupling. Still getting used to it, but I do something new each flight. Hey anybody want to trade something for a thunder tiger raptor 30?
I used 30% expo in all the control surfaces!
#1312
ND
mix flaperons/spoilerons to a slider or variable control on your radio if you have one. I run fairly extreme settings, the flaps/spoilerons are at max travel of the servo, so full down flaps will only use one servo for aileron inputs.
I've also tried mixing elevator halves to aileron, that almost cost me a plane! I suddenly acted like it was extremely tail heavy in turns. the tail would dip and it would bleed off airspeed, stalling it every time, even when in normal speed flight.
other then that, some people mix rudder to elevator to correct KE coupling. if you have variable flaps you can accomplish this to some degree already, so I've never found that mix to be of much use.
#1313
AZ
Hey DPRC, I'm no expert, But I do have about 60% expo on both
the elev and ail. I have dual rates set at 60 and 100% But I fly on
high rates only except when practicing rolling circles and attempting
rolling harriers. My throws are set for everything I can get including
my radio... The only mix I use now is rudder-> elevator about 4%
and rudder->ail at about 50%(still adusting) for K.E.s... I also use
spoilerons for harriers which is set on my flap switch...
#1314
TX
That is all good stuff. I really appreciate it. I'm just starting to be able to hover and want to set my plane up to do the other cool things that the plane can do. I know the plane can do some good stuff, it's just the pilot keeping it from happening. Anythin else you got as far as hints would be great.
Daniel
Daniel
#1315
KS
Just have a ball with it, and keep it a few mistakes high when you try some thing new! Just remember, if you get into trouble and a few mistakes high, release the sticks, see whats happening, then correct. Staying up high dosen't look great, but when you are learning new moves, it can save your plane! Just watch out for the infamous figure 9.
#1316
AZ
Hey Daniel... All I can say is Practice..Practice and more practice:-)
That's about the only real thing that helped me... As I said I went thru
2 gals. of fuel within the last week.. I did stay home today:-(.. I had to
make ado with the boss since my purchase of the Yak... I'm by no
means good, Altho I can hover the UCD at will.. Still a bit of the shaky
thumbs when I get down to 5' and below... Main thing I can say is just
go with the flow, small moves.. find the "sweet spot" and when the
thumbs start to act funny try something else for the moment that you
can do better, Then get right back doing what was a little harder But
start higher becasus its eaiser, If anything because you have more
thrust to work with, And the height will remove the ground effect that
works on you brain/thumbs which is not good for the plane
#1318
AZ
Hey CeeGee.. It's where you go in to a Knife Edge and while applying
the rudder in the K.E. the plane either pulls to the belly or canopy so
you need to apply some elev also to correct for this, Or you can "mix"
it on your computer radio... (Rudder(master).. to Elev...(Slave)) That
way all you have to do is activate a switch when doing a K.E. and both
surfaces move with just the rudder input.... Same with the Aileron if
the plane also rolls with the rudder input... Both are set by the same
switch on my radio... I.E. I have 4% Rudder to Elev. and About 50%
rudder to ail.. on my UCD... I activate the switch and when I use the
rudder the other two surfaces move along with it...
Sorry about that... I have 3* R-E & 25% R-A....:-) I'm still playing
with the settings...
#1320
My Feedback: (17)
ID
Barry
#1321
AZ
hockeyrules99... You wouldn't say that in the Summer:-).. Still can fly
then, you just have to get up before sun rise, so you can get a few hrs
flying time before your all wet :-0
Barry.. The way I do it.... It is a "stunt".... And a funny one at that:-)
#1323
AZ
I just have not been able to do flat spins:-(... I get to the stall, Give up elev.
rudder.. some throttle and what ever on the ail... But it just don't work out
for me.. The nose keeps wanting to go down.. more throttle and it starts to
roll out... I tried the invert flat spin and it seemed like it was going to do it,
But then it also rolled out... But it was the closest I ever got to doing one,
not that I do it a lot, but working on it:-)... Now an "inverted" flat spin right
into a landing... That may be something to watch someone else do...
Dang... Their showing rain for the next 3-4 days:-(.... I should have gone
to the field today..... Well, at least I got some benny points with the boss..
#1324
I used Du-Bro pinned hinges, and 30 min epoxy ,,,, 50 plus flights and no problems. I don't ecpect any either. Additionaly, the pinned hinges are alot easier to install as well.
#1325
My Feedback: (17)
ID
Hope this helps,
Barry
