Reload this Page >
Hair Raising Dead Stick-Check this out!!!
Old 05-15-2009, 02:20 PM
LostMyPlane
LostMyPlane's Avatar
Default Hair Raising Dead Stick-Check this out!!!
I was flying my newly built EF Yak 54 when at about 600’ my motor shut off. Check out the pictures below to find out why!!
Made for a very interesting landing, but yes she lives on!!!!!!!!
Max
ID:	1198775   Click image for larger version
ID:	1198776   Click image for larger version
Old 05-15-2009, 03:43 PM
Super08
Super08's Avatar
Default RE: Hair Raising Dead Stick-Check this out!!!
Close one!!
Old 05-15-2009, 04:00 PM
daveopam
My Feedback: (9)
daveopam's Avatar
You should go buy a lottery ticket.
David
Old 05-15-2009, 04:02 PM
foodstick
foodstick's Avatar
yeah you got lucky there, one or two small cables saved you from a possibly ruined motor, and a bunch of tail damage when the plane landed tail first. I can tell you from past experiences though it is interesting watching the show when you lose 5-6 pounds off the front of an airplane from a high altitude....Once I saw a giant g-shark blow the motor off, it looked like a lunar module seperating from a rocket, then the big ole tail heavy fuse and wing did a weird slow speed slide/harrier down to the ground almost level,only thing the plane broke was the elevators when it hit, and it probably weighed 12 pounds without the motor... I think the motor crank was severly bent, i mean when you drop a gas motor from about 200 feet and it bounces about 5 feet high...there tends to be damage !
Old 05-15-2009, 10:53 PM
LostMyPlane
Anyone got a good suggestion for a good strong motor mount? I'm using the Brillelli 46cc gas engine.
Old 05-15-2009, 11:03 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
DA or DL standoffs (for 50cc).
Old 05-16-2009, 01:10 AM
flygilmore
flygilmore's Avatar
ORIGINAL: nonstoprc
Uhh, dude, this engine is beam mounted, standoffs don't work
Old 05-16-2009, 04:34 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
ORIGINAL: flygilmore
ORIGINAL: nonstoprc
It should when the engine is replaced :-)
On a serious note, I guess you need to customer order a very strong beam mount.
Old 05-16-2009, 07:33 AM
panzerd18
panzerd18's Avatar
This nearly happened to me. I dead sticked and landed to find only one engine mount bolt still there. Very strange.
Old 05-16-2009, 08:13 AM
foodstick
foodstick's Avatar
have used these on my poulan 46cc...had good luck with them. ou have to file a small part of the beam for motor case clearence and drill the motor mount holes...
http://www3.towerhobbies.com/cgi-bin...?&I=LXD631&P=7
think some of the other dubro mounts have longer beams on them, but this one works good if you don't need to slide the motor out..
Old 05-16-2009, 10:08 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Just curious. What kind of beam mount was it?
Old 05-16-2009, 10:21 AM
LostMyPlane
FoodStick,
Wow, never would have thought that duo bro mount would have been strong enough. how long have you been flying with them?
Old 05-16-2009, 05:52 PM
foodstick
foodstick's Avatar
I have had them on some planes a couple years. If everything is balanced out they haven't given me any any problems. I broke one on a dead stick when I had to do an emergency landing next to the levy at our field, unfortunately my depth perception at 200 foot put me RIGHT IN THE DITCH ! rats!  The other one I broke was a scary accident when a blade thru off a motor we were setting. We were being as careful as possible and a tiny screw driver was dropped and bounced thru the prop arc.. that made the entire plane buck like a freaking mule and broke the mounts.
I get so worried watching people in front of motors. My friend and I keep telling people to point them out ,take all precautions. We always try too ourselves, but we had a close call that day... There is definately a reason to be over cautious, because it takes so little of a mistake for things to go horribly wrong.  I get shivers everytime I think about that incident...
Old 05-18-2009, 10:59 PM
Spitfire222
Spitfire222's Avatar
That's disconcerting. I have the same engine and I've been unsure about which mount to use. I definitely wont be using the one you did!
Old 05-19-2009, 10:37 AM
LostMyPlane
if you come across a good strong mount, let me know. I'm gonna be checking out the dubro mount when I can get to my LHS, but haven't decided yet
Old 05-19-2009, 01:52 PM
T Erickson
T Erickson's Avatar
Try Brillellicustoms.
Old 05-19-2009, 04:13 PM
LostMyPlane
ORIGINAL: T Erickson
That just happens to be where I got the first mount. I like there mount, was hopping to order another set from them but request something a little bit wider, but I don't see an e-mail address to ask if they have any.
Do you know anyone else that might make gas motor mounts?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
