Hype 3D or not?
Hi Guys,
I have been reading with much interest all your views on the Hype 3D and West .50 Ti combo. Sounds good to me, but what are the pitfalls to a newcomer? I am new to this type of flying, usually flying scale, sport and pattern models. I really can't decide what to get, but it will need to be ARTF. Does anyone know about the CZ KABRIOLIN sold at Ali's? If so, how does it compare to the Hype 3D? This seems to have alternative wings for pattern flying. Any help will be greatly appreciated. By the way, I may be able to borrow an AEROFLY PRO flight sim ..... do you think this will help me along the road to successful 3D flying? ...... waiting with baited breath, Dave |
Hype 3D or not?
UKflyer i have the hype3d with the west combo and i totally love this plane...ive only been flying since march/april this year and i can hover it quite easy even though its about 30ft up but im still learning and slowly bringing it lower and lower.....
the west engine is superb never quits and loads of power to pull from the hover.... |
Hype 3D or not?
:) Thanks Miskin, thats encouraging to hear. Are you saying that you only started in RC modelling in March/April?? If so, you have done remarkably well!!
Did the 'kit' come complete including all necessary hardware - The WestonUK site doesn't seem to give details of what's actually in the box! Also I would be interested in hearing what servos you have installed, especially at the rear end ..... Thanks Dave |
Hype 3D or not?
UKflyer.
You don't have to set the controls up for full 3D throws! Try programming all rates to one switch, therefore you can get used to the plane with it set up soft and flick in high rates when the mood takes you! The Hype is very forgiving and will make a great second plane. it comes with all accessories I use standard 3004 servo's on 6 volts - no problem. My prophanging confidence is building with this model. |
Hype 3D or not?
UKflyer the hype comes with a complete hardware pack(tank,horns,closed loop etc)..all you need to add is radio gear and engine..
the servo's im using are basic futaba 148's apart from the elevator which has a futaba S9402 Coreless Servo im also running a 6v batt and yes i started rc in march/april and love every minute of it |
Hype 3D or not?
My setup is similar:
ailerons: Futaba S3003 throttle: Futaba S3003 (or whatever You have on hand...) rudder: GigaLine Torque servo (6 Kg) elevator: Futaba S9001 coreless All are running on 6V 1200mAh pack. I could easily get away with standard servo on rudder but little stronger on will not do harm. I am pretty reluctant on tail modifications for dual servos as Hype is built extremelly light. Cutting rear part of tail for servos might compromise structural integrity. I have seen this done with succes but I would (and am...) avoid it. As far as airplane is concerned all good for it, especially with West 50T1 and Genesis pipe combo. I had problems with it for a while but it was solved easy :) |
Hype 3D or not?
hi
do we know any AUWs? revs of the .50 and which prop thanks |
Hype 3D or not?
do we know any AUWs? revs of the .50 and which prop West 50T1 spins APC 13x4W @ 11800 rpm |
Hype 3D or not?
mine came out as 6 1/2 pound's
the west t1 with a 13x4W @12100 on prosynth 10% nitro |
Hype 3D or not?
PHEW! i thought my Capiche was heavy at 5lbs with the West 50 :p
big thumbs up for the West 50 |
Hype 3D or not?
West 50 pulling a flip
13x4w at 13,000rpm Ian |
Hype 3D or not?
1 Attachment(s)
Hype...West .50T1 and Genesis pipe.
Prosynth 10% Standard servos on 6volts .....big fun. |
Hype 3D or not?
1 Attachment(s)
another
Hype 3D or not?
That looks a nice patch to fly at. is it a privet field or a club?
How heavy is 2.5kg in lbs? Ian |
Hype 3D or not?
edible....you need to spend your summer hols brushing up on spelling
and weights and measures. :p |
Hype 3D or not?
HE HE HE......LOL
Hype 3D or not?
I saw the ad for this plane in a Brit R/C mag at my LHS and it looked pretty. :) Shame we dont carry it anywhere around here.
Arnie, whats the pic in your avatar? Nice lookin bird as well. |
Hype 3D or not?
the Hype? it is over there. Model-baul, ModelBual? what ever it is, they do Cougars, should have Hype's too
Hype 3D or not?
Thanks to all you guys for the useful info .....
....... and great pics too Arnie ........ hope I can do that soon Gonna order mine this week ........ Is it a one piece wing? |
Hype 3D or not?
Gonna order mine this week ........ Is it a one piece wing? Wing is one piece. |
Hype 3D or not?
aerofly pro will help your 3d flying a lot, so buy it!
If you are borrowing it, you will need to make up a lead identical to the IPACS lead, other wise the sim wont work. |
Hype 3D or not?
Id like aerofly pro. but 99quid is expencive. and i need my capiche.
Ian:( |
Hype 3D or not?
edible. bye it. wheel emprive your fliing. ey've lurnt a lot on Myne.
Hype 3D or not?
i would get a capiche instead though for the time being.
My problem is that all the stuff ive learnt on aerofly pro, i havent got a plane to do it with in real life! I cant wait to get mine. |
Hype 3D or not?
Do aerofly do a speeling simulater?
:D |
| All times are GMT -8. The time now is 10:44 AM. |
