Seagull's HARRIER 90,WHICH SERVOS & ENGINE
Hi Friend's,
i want to assemble for 3d.. 1 ) I have Seagull's HARRIER 90 packed and planning to assemble it, so which servos are the best in terms of kg,? 2 ) Which engine is best for it , shell i go for 2 stroke pump enngine ? kapsidem |
RE: Seagull's HARRIER 90,WHICH SERVOS & ENGINE
I put 635 hb hitec's on ailerons, 645 mg on ele and rudder mine, never have had a complaint. i do run them on 6v. The rudder does like the torque of 645. tried the 635 and could feel it blow back, switched to a 645 and it brought the rudder response to life.
power is up to you, i powered mine with a saito 100 and it does what ever ya want to do. Its a fun plane you will like it alot. Beef up the firewall, i pinned and glassed mine after 5 flights because it came loose. and glue a couple extra runners on the hatch, hatch is kinda weak right in front of the canopy. balanced with the battery just behind the wing tube with that set up. |
Servos: Futaba 3305, 3010, Hitec 475 /485, 645MG. Anything Hi torque basically and preferable with metal gears standard servo
Engine: 2C: 75AX, 95AX 4C: FS91SII Remenber engine is inverted mounted. Resist overpowering and overspeeding the airplane. It is built very fragile Ameyam |
what about this:
servos Hitech : <font color="#0066cc">HS5485HB</font> for alleron alivate & rudder. For throttel any 2kg <u>Engine</u> OS: <u><font color="#800080">91VR-DF</font></u> |
OK I GOT IT <u><font color="#800080">91VR-DF</font></u> is best for for deducted units i think 95AX is the best for seagulls harrier 90 . but one thing is still there in my mind is, i have heard that for 3d flying we need pumped engines, sois that correct? |
Pumped engines help in that pump keeps the flow to the engine remains constant no matter what the attitude of the airplane and fuel level in tank. However, the way I see it, the pump is another piece of equipment that may fail or get damaged. Even without the pump, the engine will remain reliable if its setup and run-in properly. The pump just becomes another thing to worry about
Ameyam |
OK thamks to realize me ,
so am gona use OS-95AX, WITH hitech <font color="#800080">HS 5625 MG</font> servos is configuration fine ? |
Yes, sounds good. Go for it and enjoy the airplane[8D]
Ameya |
When you get your harrier finished, will you PLEASE video it doing a harrier??? The one and only review of the "Harrier" never mentioned how or if it would harrier.
Thanks much, JW |
RCGroups has a Seagull Harrier review (I think). You can also google it. When I was considering taking that airplane I had read up a lot. Ultimately saw too many problems and moved on
Ameyam |
