RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Brelleli 46 question (https://www.rcuniverse.com/forum/3d-flying-82/10397253-brelleli-46-question.html)
DEVILDOG 03-13-2011 10:35 AM
I have a Brelleli 46 that I haven't used for about a year. There are 3 lines off of the carb. One goes to the crank case, one goes to the fuel tank, and the other on is the one in question. I can't remember what it was used for. I think it just got plugged and not used but it's been over a year since I put it to use.
I hope someone can help me out here.
thanks
Scott
flygilmore 03-14-2011 10:03 AM
RE: Brelleli 46 question
Plugged if it was like the one i had. Mine had a Tiloston carb on it[:'(]
Uncas 03-20-2011 05:09 PM
The other line is a pressure equalizing line that should run back inside your fuselage. I had the Zama and I now have a Walbro. It was needed for both. In fact I installed a nipple on the Walbro and closed up the local vent just for that purpose due to mixture problems in flight.
FYI - it is Brillelli.
Good Luck!
