RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Wing Loading???? (https://www.rcuniverse.com/forum/3d-flying-82/1076488-wing-loading.html)
lxcoupe 08-21-2003 04:30 PM
Wing Loading????
What is the formula that you would use to figure out what the wing loading of a particular plane would be.
AL
Sprink 08-21-2003 06:36 PM
Wing Loading????
Weight in oz divided by wing area in square feet gives oz/sqft.
Casey Frost 08-21-2003 06:47 PM
Wing Loading????
Wing loading is usually listed as Ounces/Sq Ft.
Example
So on a UCD3D the wing area is 1072 sq in.
To convert that to square feet you divide it by 12 TWICE to get 7.44 sq ft.
Advertised weight is 7 lbs to 7lbs 6oz. wishful thinking.
More like 8 to 9 lbs.
But lets assume the factory weight for now.
convert pounds to ounces by multiplying 7 by 16 (16 oz per pound)
That would give you a range of 112 to 118 ounces
112/7.44 = 15.05 oz/sq ft
118/7.44 = 15.86 oz/sq ft
Realisticly 8-9 lbs it comes in at 17.2 to 19.35 oz/sq ft.
So like golf, the lower the number the better (slower it will fly before stalling)
lxcoupe 08-21-2003 06:52 PM
Wing Loading????
awsome!!! Thank you. I had everything right except the divide by 12 twice part...DUH!
Thanks Guys
AL
Ed_Moorman 08-21-2003 07:02 PM
Wing Loading
if you can remember the number, you can divide pounds by square inches and multiply by 2304. 2300 comes about as close as most scales.
7 / 1072 x 2304 = 15.05
7 / 1072 x 2300 = 15.02
Just remember 2300
JohnW 08-22-2003 07:15 PM
Wing Loading????
Since this is the 3D forum, figured I point out quickly that wing cubic loading is often a better indicator of flight performance than area loading. To find cubic loading, divide the weight of the plane by the volume of the wing.
Casey Frost 08-22-2003 07:55 PM
Wing Loading????
If I can't use my fingers and toes to do the math, I'm pretty much done.
I imagine it's quite elaborate to calculate a wings volume. Please tell us more!
