looking for MoJo 40 specs
Does anyone know how long the MoJo 40 is? I'm looking at building one but I'm not sure if it will fit in my car without a removable wing..
RE: looking for MoJo 40 specs
Change cars if it doesn't fit. Seriously, its that important.
Building a 40 size with removable wings makes them heavier and weaker. It's 46" span by about 48" length depending on engine placement to attain CG. |
If you have a tight car you could disconnect the ailerons and elevator from their horns and allow them to fully deflect as you place the Mojo in.;)
<span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Arial","sans-serif"; FONT-SIZE: 9pt"><p class="MsoNormal" style="LINE-HEIGHT: normal; MARGIN: 0in 0in 10pt"><span style="FONT-FAMILY: "Arial","sans-serif"; FONT-SIZE: 9pt; mso-fareast-font-family: "Times New Roman"">Thanks for the info. The MoJo 40 is slightly larger than what I'm flying now but it should fit in my car just fine.<span style="mso-spacerun: yes"> </span>I scoured the internet; including this forum, and I couldn’t find a length for the plane anywhere. Swany should really add the length to the plane's specs on his website.</span><span style="FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt; mso-fareast-font-family: "Times New Roman"">
</p></span></p></span> |
go to the P r o f i l e b r o t h e r h o o d site and more will be revealed!
Hang low with a Mojo baybeeee!!!!! |
| All times are GMT -8. The time now is 10:50 PM. |
