RCU Forums
-   3D Flying! (https://www.rcuniverse.com/forum/3d-flying-82/)
-   -   Next model? (https://www.rcuniverse.com/forum/3d-flying-82/1090435-next-model.html)
antsis 08-26-2003 10:14 AM
Next model?
I have a Hype 3d with an OS46FX and 11X7 prop. I'm not that taken with it even though it performs well enough. I don't really want to lash out £167.00 for the recommended motor and pipe, so am considering selling the airframe, but keeping the 46.
Any ideas on a suitable replacement. I'm quite interested in the flair giles 40 3d.
Ian.W 08-26-2003 10:22 AM
Next model?
mmmmm, id get that engine, ive got one, its bl :D :Ddy amazing, i cant really describe it, but i'll try: west 50T1 turning a APC 13x4w at 13,000rmp, my flip is heavy:2.5kg and this engine/prop combo gives me a 2:1 power to weight, AMAZING
outherwise, if you dont whant the engine, i wouldent get the the giles, performes less than the hype.
where are you in the UK, come the the RCM&E freestyle comp and get some good proper advice form people of the likes of Ali M
antsis 08-26-2003 11:17 AM
Next model?
I should keep the hype? Where is the RCM&E comp? I'm in Kent.
Ian.W 08-26-2003 11:40 AM
Next model?
id keep the hype, although id strengthen the tail as this a weak point (use wires) and get the west engine, make sure its the T1 NOT the V1. this'll make it perform real good.
the RCM&E comp is just off stevanage, not to far if you can drive. To be presised its a mile or 2 of knebworth house, see http://www.rcuniverse.com/showthread...02&forumid=230
this will give you all the info you need
PS, change that prop first, use a 12.25 x 3.75, it'll be a better fun fly propp
antsis 08-26-2003 11:52 AM
Next model?
I will have to wait a while before I can get the motor. Early xmas pres maybe. I was just going to put stiffeners inside the fus to strengthen it.
Ant
Ian.W 08-26-2003 12:02 PM
Next model?
try get that prop though, it'll improve the flight, see, if you got a high pitch prop it'll go fast and fall apart, and it'll stuggle abit on hove pull out, its only a fiver, so get one!
Cactus. 08-26-2003 08:12 PM
Next model?
i was gonna say that, ditch that prop? you the only guy with a fun fly in your club? been to the John partridge school of over propping? all funflys are sub 5" pitch, 4" is better. umm 46.. 12.25x3.75 should be good, or a 12x4. then you'll get the hype to fly right.
Hercmate 08-26-2003 08:59 PM
Next model?
I second (or is that 3rd now?) the prop change but try an 11x4 as well as the 12x4 and 12.25x3.75. See which you like the best...... I would bother with the giles they're very heavy and you'll probably be disappointed. Good luck with whatever you decide!
antsis 08-27-2003 05:53 AM
Next model?
Thanks for info. I'll try a 12 x 4 this weekend and then decide.
